Question about Taylor H84 Soft Serve Frozen Yogurt Ice Cream Machine Single Phase Air Working
Looking at a H84-27 how can you tell if its air cooled or if its water cooled?
Part number on the machine is 0h8427b000 if this helps
    Scholar:
  • 81 Answers
Air cooled units will have refrigeration condensers, ie: the fins for air to pass over. Water cooled units have water hook ups and black coils inside.
Posted on Apr 30, 2013
Compressor hpco code comes up on panel of Taylor soft serve ice cream machine? Does that mean lack of water to machine?
There is a very good chance. Often the water has been shut off, or a wheel is pinching the hose.
HPCO stands for High Pressure Cut Out. The high side pressure is regulated by the water valve on water cooled equipment.
These are links to parts in the water cooling system.
046686 Water Regulating Valve 3 8
048287 Condenser for Taylor Water Cooled machines Taylor 035174 Scraper BladeReplacement 17
May 28, 2017 | Taylor Ice Cream Makers
Compressor hpco
Compressor hpco or (High Pressure Cut Out) means the high side pressure has went over the limit the machine has been set too. The safety is there to protect the compressor. If the machine is water cooled, the water flow has most likely been interrupted. So often the machine was moved for cleaning and the wheel is on the water hose. If the machine is air cooled, Either 1. the fan has stopped, 2. the condensers are dirty or 3. It's just too hot where you are trying to run the machine.
Soft Serve Parts C723
May 06, 2017 | Taylor Ice Cream Makers
Gongly soft ice cream machine won't work. Beeping sound when power is turned on. What is the problem?
manual control soft ice cream machine, View carpigiani ...
gongly.en.alibaba.com > Product Categories > Soft Ice Cream Machine
manual control soft ice cream machine,US $ 0 - 1000 / Unit, Air-Cooling, CB, CE, ... Brand Name: GONGLY; Model Number: BQL-838; CERTIFICATION: CE/CB, ...
Machine glace italienne www.gongly.eu - YouTube
? 6:48
https://www.youtube.com/watch?v=D7c2Hiwi6FQ
Jan 3, 2011 - Uploaded by TvSTORE
Machine glace italienne www.gongly.eu. TvSTORE ... Jin Li Sheng Fry Ice Cream Machine Fried Ice Cream Machine Fry Ice Pan Machine ...
Hot Sale Jin Li Sheng BQ322 BQ332 Soft Ice Cream ...
? 1:14
https://www.youtube.com/watch?v=ChUllkdJMlc
Jan 14, 2016 | Ice Cream Makers
What is process to winterize a Taylor ice cream machine?
To winterize a Taylor 794, or almost any water-cooled Taylor machine, we need to get all of the water out of it. Follow the steps outlined here.
1. Remove the supply water hose from the water source.
2. Remove the rear panel of the machine.
3. Locate the water valves. Pictured below.
4. Have one person open 1 water valve. (You can scissor two screw drivers to take pressure off of the spring.)
5. Blow out all of the water with an air compressor until only air comes out of the drain hose.
Repeat step 4 and 5 for the other side.
Sep 15, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
TAYLOR ICE CREAM MACHINE DISPLAYS HPCO COMPRESSOR.WHAT DOES IT MEAN AND HOW DO YOU REMOVE THIS CODE
HPCO is an acronym for High Pressure Cut Out. The most common causes of this code are either an issue with the fan in air-cooled equipment, or an issue with water flow in water-cooled equipment. MOST of the time, someone has mistakenly shut off water to the unit, or moved the machine and pinched a water line with the caster wheel. A restriction at the expansion valve is a possibility but unlikely unless the refrigeration system has been opened recently, possibly to replace a compressor or other component.
If you would like to discuss your issue further with a technician, call 1-800-879-7839. http://www.softseveparts.com/
Sep 12, 2013 | Ice Cream Makers
I loaded the machine with mix and turned it on but machine keeps on turning but mix is still very watery
My small Business had this same problem. The first thing you need to look at is the product you are using. It turns out that if you are making your own soft serve. which Includes water and powder, it will save you a lot of time and stress to switch to cartons of soft serve that you just pour right in. It turns out that there is no consistency in powder icecream. the water will eventually separate from the mix, resulting in watery soft serve once dispensed from the machine. Next, if this isn't the prduct you are using then it can be other problems such as your compressor not working, or turning on when it's suppose to, maybe you have a weak motor, or your machine isn't set to the proper freeze level, Also, make sure that your machine isn't backed up against a wall or I between two other machines. These machines need to Obsorb cool air in order to work properly and not overheat . The machine's fan, which is located on the right side, needs to be have a certain amount Of space from walls or other machines. If this doesnt work you can always call a technition to come and check out the machine, I hope this helped, best wishes with your repair
Jul 16, 2011 | SaniServ 401 20 Quart Ice Cream Maker
I hooked up my gauge run the unit and sees the high side pressure goes up, the compressor overheating and shuts off. I checked the water pressure regulator valve it good. so I unwelded the condensor coil...
It sounds like you may have unwelded the suction line to the compressor and blew the compressor out. That is not good. How a Taylor works is this: Compressor comes on and produces a lot of heat. There are 3 ways to dissipate the heat. If there is a big radiator like set of copper and aluminum finned coils near the compressor it is air cooled. If there is a water line going in and a drain line coming out, it is water cooled, the water runs the whole time the compressors are running, the third way is to have an outside remote condenser coil. I believe you have a water cooled machine. On the back of the machine is a copper fitting to hook up the incoming water lline. There is also a drain line and water will flow constantly from it if everything is running alright. It is ok for the compressor to get hot when running, it is supposed to get hot. If you broke into the freon lines by mistake, the freon is gone and it won't show pressure anymore. I don't see any way that oil would have gotten into the water cooling line. To verify which is the cooling water, the copper lines will go into the back of the machine and will be wrapped around the outside of the compressor and then back to the drain at the back of the machine. If you blew the oil out of the compressor it will very soon lock up and be destroyed. Look at the line that you cut into.
Oct 20, 2010 | Taylor 632-27 Ice Cream Maker
I bought a used taylor ice cream machine. It is model number 8756-27 and it was manufactured in 1987. It is a water cooled machine ... Do you know how much water it uses daily?
You use ICE, not water and then rock salt is added over the ice to lower the temperature for making the ice cream.
The salt hastens the melting of the ice and thus lowers the temperature.
Nov 13, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Taylor H84 Soft Serve Frozen Yogurt Ice Cream Machine Single Phase Air Working Logo
128 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
