Question about Dell Latitude D505 D510 D520 D530 D531 D600 D610 D620 Replacement PA-10 AC Power Adapter Charger (DELLPA1013) AC Adapter
What's the pinout inside the Dell adapter pa-10?
I have a Dell latitude D600, the charger whas beeping and not working. Someone repaired it for me, but he forgetted to connect the IDentification lead inside the adapter. I opened it (ofcourse without any power on it) and the white wire goes to the GROUND (negative), the black one goes to the V+ (positive). Next to the GND there is the ID hole, but which wire do i use for the ID ? I Founded this: http://www.laptop-junction.com/toast/sites/default/files/wires-DELL-PA-1900-02D2-AC-power-adaptor.jpg and see only the black and white wire ... Whitout that the laptop battery won't charge and cpu runs on slow speed (600Mhz). Please help me if you have any advice for me =D
StuartB
  • 807 Answers
SOURCE: AC Adaptor DELL PA-12 checking
See what the output voltage the adapter says, it may be 19.5VDC @ 3.34A.
Set the Multimeter to read 20 volts DC or more.
Put the Black lead on the outside of the plug (negative), and the Red lead inside the plug (positive).
They usually have the positive as the hole in the plug.
Look at the reading on the meter, if the power adapter is working it will read around about the stated voltage but none of them are completely accurate. It may be a little more or a little less.
If it is nowhere near the stated voltage then there is a problem with it.
Posted on Mar 13, 2008
  • 2418 Answers
SOURCE: My Dell 6000 power adapter does not work
Dell's are the worst. First is the wire broken out sidde the box? Most I have repaired have broken at the plug real close to the end that plugs into the computer. Looks fine but the wire breaks inside the insulation. I slice the insulation back looking for the brake, cut each wire at different locations, so you do not get a large patch in the same place. Solder the wires back and tape them up = match color for color.
Posted on Jul 24, 2009
  • 20 Answers
SOURCE: power
Look under the laptop. There should be button to push to the side(it has a lock picture). After pressing it the hard drive will come out( i dont know if it is a hard drive). After it comes out put it back again. It should help. It worked for me.
Posted on Aug 08, 2009
ihwsolutions
  • 137 Answers
SOURCE: dell inspiron 1501has no power connection
Sounds like the PSU connection has been broken from the motherboard.
Your laptop will be required to be taken in for service
Posted on Sep 27, 2009
bahratt
  • 561 Answers
SOURCE: I have a Latitude D630 laptop and I recently
Try updating to BIOS to version A16 from http://support.dell.com Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Posted on Dec 30, 2009
I have a Dell Latitude D600 power problem. When the AC charger is connected the unit will power down by itself within 10 secs the most. If no AC charger connected, the unit is fine.
Please try removing the battery then attached the ac adapter and see if the same thing happens. It is possible that the AC adapter is faulty already if it doesn't isolate the issue. Please let me know if the result. Thank you and regards.
Sep 25, 2010 | Dell Latitude D600 Notebook
Hi i am using dell latitude d600 problem with charging the battery 3 or 4 time orange light flash n 1 time green light . im unable to use my laptop with battery it working well with A.C power
Try to perform power drain. Take out the battery unplug the power adapter then press and hold the power button for 30secs. Put the battery back in then plugin in the power adapter then turn on the computer. If same issue occur, then you need to replace your battery.
May 18, 2010 | Dell Latitude D600 Notebook
I can't get the computer to recognize the charger. It flashes between battery and charger unless the charger is being pushed in. I have tried numerous chargers with the same result.
With the charger unplugger, look inside the plug end that you plug into the pc. On occaision, the center pin may be damaged or pushed into the plug itself. That small pin is what provides the laptop the power (wattage) info. Also if you know anyone else with Dell charger PA-10 or PA-12, try theirs. Good luck!
May 12, 2010 | Dell Latitude D600 Notebook
Dell Latitude D600, installed new battery, but still won't charge.
Try to use another ac adapter or charger,.. If that doesn't work you'll need to replace the motherboard.
Usually this issue gets fixed by updating the BIOS of the computer but if the battery is less than 10% charge then you won't be able to flash the BIOS that will end up replacing the motherboard.
Feb 13, 2010 | Dell Latitude D600 Notebook
My dell d600 been shorted after using defective charger
try connecting a known good ac adapter if fails then remove battery then try it again if still fails then replace the motherboard.
Oct 14, 2009 | Dell Latitude D600 Notebook
Dell D610 only can run on battery, not accepting AC power or from my docking station. I check the PA-12 AC charger and is working fine with other D610. Please help.
If not powering from DOCK, AC adapter and only from battery, since the Battery, DOck and adapter are known good, it is a matter of a motherboard replacement
Jul 09, 2009 | Dell Latitude D600 Notebook
I have a Dell Latitude D630, and I have had it for less than a year, and my charger is broken. I have it plugged in and everything, and it is not working. I plug the adapter into the outlet, and the...
sorry, i have to say this-- make sure the outlet works-- or try out a different outlet. :-)
ok, then make sure the connection is tight between the 2 parts of your adapter, it may have come loose.
other than that, you have a dead adapter. laptop companies are very good about replacing them for free under warrantee. they dont want fires starting at someones home because of a 30 dollar part.
i just called my laptop company, hp, 1 week before my 1 year warrantee ran out, and they shipped me a new power adapter, free, overnight.
call dell, tell them, they'll ship you a new one with usually free shipping, and usually in a day or two tops to your door.
Jan 31, 2009 | Dell Latitude D600 Notebook
Latitude Charger wrong
Firstly, you should try to use correct sentence structure.
Secondly, as long as it's a pa-10 or pa-12 for the d600 you should be fine. the chargers are not specific to each laptop, rather they are more specific to the dell product family(the type of power connectors on each).
Jul 09, 2008 | Dell Latitude D600 Notebook
D600m dell laptop
the power adapters are known to have problems
Mar 29, 2008 | Dell Latitude D600 Notebook
Dell Latitude D505 D510 D520 D530 D531 D600 D610 D620 Replacement PA-10 AC Power Adapter Charger (DELLPA1013) AC Adapter Logo
525 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
