Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
E35 error code
Stuck on spin cycle, will not drain
  • timfink Nov 04, 2012
    Washer error is E 35. Was told to run a clean cycle to see if this clears the problem. Well, it doesn't. Any suggestions? There are no electrolux repair technicians within 150 miles of my house. Any and all help is appreciated.
    Problem Solver:
  • 21 Answers
Chec the drain pump, if there is a coin blockingthe whole
Posted on Nov 04, 2012
I have oven electrolux MODL. .EW30IS65JSA ..its has problem error .E35 how I can salve this ??
Hello Awad, thanks for your inquiry!
From what you have described your Electrolux range is displaying an error code of E35. I am not showing that as a valid error code, maybe a digit or the panel is misreading. I would suggest performing a reset on your range to see if that would help clear any faulty codes. You can reset the range by disconnecting the power cord for at least ten minutes. If you continue to experience an issue with your range I would recommend seeking additional assistance from a professional technician. I hope this information is helpful to you. -Matt
May 05, 2016 | Electrolux Ovens
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Cannot get a spin cycle, washer gets stuck before spin cycle get F6 error code
You will need to access the drain pump first by removing the bottom panel. Open clean-out on pump and check for obstructions. If none, the pump may have a broken rotor, these are the problems related to the F6 code.
Dec 01, 2010 | KitchenAid KHWS01PMT Front Load Washer
Error code OF 2 When this error code appears it happens during the spin cycle. I manually switch to the Drain/Spin cycle and change the spin speed to medium and press start. This fixes the problem each...
It sounds like you may have a motor control board issue. It acts like the motors brain and tells it what to do and when. part number 8182706. Also the closet error code i could find is a f/02 which means long drain, which could indicate a bad pump or draining cycle, alos knows as the spin cycle This should definetly be diagnosed by a technician. hope this helps
Thanks
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No error codes-washes but does not spin- water stuck in bottom
If your machine is a FAV6800A to FAV9800A here is the Service Manual.
If you lift the washer lid and rotate the wash basket CCW which is the Spin Cycle direction will it turn with very little resistance? It should not rotate CW.
With no error codes I would go to Service Mode page 14 of the Service Manual and read the current recorded Daig codes and write them down then clear the list.
Now start a Spin Only cycle with no clothes in the wash basket let it in that mode for about 5 minutes. Hit the off button to end the Spin Onlly cycle then check the Diag code block and see if an error event was logged if so please let us know.
If there is no error code generation by the Control Board in the Diag code blocks I would suspect a Control Board issue with your no Spin issue..
Without a known good Control Board and Motor Controller to swap out and no error code generation by the Control Board this would be a hard problem to troubleshoot.
The Control Board is under warranty for 5 yrs you could try Maytag Customer Service the number is in the SM and see if they will send you one even if the warranty is up…..Rich
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code nD, won't go into spin cycle
Is the Machine a FAV6800A or a FAV9800A?
Do you want to DIY the fix?
The nd error code = No Drain error code.
You could have drain line clog, an issue with the drain pump or a stuck pressure switch. Do you hear the machines drain pump turn on and pump out water before entering lnto the spin cycle? Is there water left in the tub with the nd error code? If you can provide feedback on the questions above I will help guide through the troubleshooting steps.
You will need the Service Manual to troubleshoot.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Rich
Dec 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Seriously need help!!!
take off the bottom panel and look inside the cavity on the sidewall, there should be a plastic pouch stuck there, inside will be what we call a "tech sheet". it will tell what each error code means. i suspect that either the "coin trap" [from the tub to the pump] is plugged or there is something stuck in the pump. if the drain system is not working, the control board will not cycle to spin. it's kinda messy so lay down a lot of towels
Sep 24, 2009 | Frigidaire GLTF2940ES Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
1,087 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
