Question about Braun Kmm20 White & Off White Burr Grinder Mill 9 Settings
It stopped grinding, I took it apart and cleaned everything out, when I plug it in all I hear is the timer.
It doesn't appear to be clogged.
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 18, 2014 | Coffee Makers & Espresso Machines
Dyson has no suction and hose doesn't work
Hi Brenna, it's Jack at Dyson.
I'm sorry to hear you're having difficulties with your DC17 Absolute. I can see that you've already checked for blockages, but the issues you've describe do strongly suggest that there's a blockage somewhere in the machine. You might want to follow the steps shown in our online Support guide, as this should help you locate any obstructions you may have missed:
http://content.dyson.com/support/help.asp?article=955&product=DC17-ANIMAL
If you aren't able to find a blockage, but continue to have difficulty with your vacuum, please email us so our experts can help further. You can reach us at askdysonUS@dyson.com.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Jul 06, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Whirpool washer LSN1000JQ1 topload won't drain .
check the lid switch,open the lid,stick a screw driver into the hole where the strike on the lid closes into,you should hear a clicking sound,no click the lid switch is bad,or close the lid and open it up a few inches and close it down,no clicking sound the switch is bad.you can watch this video and it will show you how to change the switch
http://www.youtube.com/watch?v=V5aW9WkTFhEif the part number is 3949247 and the lid switch is around 50 dollars,common problem.if you hear the switch click when you stick the screw driver into the hole set the timer to spin,pull out the timer knob and then stick the screw driver into the hole again,if the switch is engaging it will drain and spin but if it doesn't click change the switch.good luck,if you need anymore help let me know.
Mar 13, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
I don't understand how to set the timer on my UP 15-10-B5/TLC Grundfos circulating pump. When it is not plugged in, we have a hard time getting hot water
Sounds like 2 problems:
1) Crossover and 2) Setting timer
Recirculation system has check valve that stops backflow of water when pump is turned off.
When check valve is clogged with sediment, or has worn out, then cold water enters hot pipe or hot water enters cold pipe when faucet is turned on.
Take apart connection where grundfos connects to both hot and cold pipes, and clean with white vinegar or CLR.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Open following link for setting typical FM/1 analog timer module on Grundfos recirculation pump:
Your timer module may vary in appearance.
Slide switch selector might be located below timer dial.
http://waterheatertimer.org/images/IMG_9325-grundfos-timer-800.jpg
Aug 30, 2011 | Grundfos UP15-10B5/TLC 1/25 HP...
Maestro Burr coffee grinder stopped grinding
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the grove and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Apr 04, 2009 | Solis Maestro G385 Electric Burr Grinder
My DCT646-2 no one can hear me.
take it apart and clean the mic with alcohol. (I took out a black round cover it had on top to reduce eco)
Worked for me.
cheers,
Oct 04, 2007 | Uniden DCT646-3 Cordless Phone
Braun Kmm20 White & Off White Burr Grinder Mill 9 Settings Logo
42 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
