Question about Jet Saws
Just purchased a JET 708471 table saw from private owner-
I am looking for a source for accessories: manual, splitter, and possibly other accessories in the future
  • David Ford
    David Ford May 11, 2010
    I went to Jets website and their database does not have that number. You can try going to Jettools.com and contacting them after rechecking the model number, its possible that its so old that they don't list it with current products, but this would be a start.
  • 23 Answers
SOURCE: need owners manual for makita 2703 table saw..
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/
Posted on Nov 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: Looking for owners manual Craftsman table saw 101.02141
I tried their site and they say no parts available for that tool, They suggest that you call them direct and I have a phone number at 1-800-252-1698 and they might be able to help. Good luck
Posted on Mar 30, 2009
  • 274 Answers
SOURCE: We just purchased a previously owned Ryobi table
Try the internet Quite often can find pdf downloadable manuals for most things
Posted on Oct 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: Looking for a source for a 36-600 manual.
got it. go to Dewaltservicenet.com and in the middle of the page at the bottom under manual type in your number exactly as you have it and you can download the manual, it is 29 pages long if I have helped you with your request would you please rate this response accordingly and thank you.
Posted on Oct 30, 2009
rowdy45176
  • 2176 Answers
SOURCE: Looking for the owners manual for the Craftsman
go to managemyhome.com and under manual type in the model number listed. The manual is 48 pages long. If I have helped you with your request would you please rate this resonse accordingly and thank you.
Posted on Jan 31, 2010
How do i adjust the blade tilt
There should be 2 handles: height and tilt. Tilt is typically located perpendicular to the blade on the base of the saw.
Dec 28, 2014 | Jet Saws
I have a jet 10 in. left tilt exact-a-saw that will not tilt. The shaft is keyed to the hand wheel and even wi
First guess would be a lock bolt is tightened down. Second guess would be a 90 degree latch or stop. Take a look at this link from "mikestools": http://www.mikestools.com/download/Jet-Owners-manuals/Jet%20Tablesaws/708661.pdf.
May 12, 2014 | Jet 10" Xacta Saw Left Tilting Arbor...
JET 708471 Manual
you can download the manual from this site
www2.woodcraft.com/pdf/708100.pdf
Sep 09, 2012 | Jet Saws
Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
May 25, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
How do I change the blade?
Unplug the saw. Remove the plate that the blade goes through this will allow access to the nut. Raise the blade several inches above table deck. Place a block of wood under the teeth to bind the blade so it won't rotate you should be standing on the infeed side of the blade. With a wrench loosen the nut (Towards You) Reverse to reinstall. It is also a good idea to wear leather gloves in case you slip the blades can still do damage even when dull. Hope this helps please rate if this was helpful in any way. Good Luck and have a great weekend.
Mar 31, 2010 | Jet 10 In. Proshop Contractor Style...
When ripping a board the width becomes narrower toward the end of the board, I have checked the fence and it is aligned correctly. the splitter is also aligned, replaced the blade and it helped did not...
Several possibilities come to mind:
1) Check the alignment of the arbor -- it's possible the arbor or arbor nut are not completely true. Detailed instructions are here:
http://woodgears.ca/saw_arbor/index.html
2) Check the alignment of the blade to the miter slots. If you aligned only the fence to the miter slots, it's possible the fence may not be aligned with the blade if the blade is out of alignment.
3) You said you checked the alignment of the fence and splitter, but these are the most common causes for the problem you're having. You might want to re-check the alignment of both, using a different method. Try these methods:
http://www.toolcrib.com/blog/2007/09/06/table-saw-alignment-for-005/
Be methodical and follow the directions for alignment closely. The extra attention you put into aligning your saw will pay you back many times over in clean, accurate cuts.
Aug 10, 2009 | Jet Saws
Need a owner manual for tradesman bench table saw model 8031
I believe I have the manual for the 8031 table saw. Are you still looking? Contact me at HollomannAFB@yahoo.com
Mar 18, 2009 | Saws
Saws Logo
278 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
