Question about Canon PIXMA MP240 All-In-One InkJet Printer
Mp499 e03 error message but no paper jammed
Tried power off holding buttons, checked there is no paper jammed but it keeps flahing e 0 3
  • Anonymous Sep 22, 2016
    I did the same as below. Pushed in a thick piece of cardboard which the printer pushed out after restarting it. It worked after that!
    Top Expert:
  • Canon Master
  • 1,144 Answers
  • 52 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Posted on Jan 23, 2009
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
pineworks
  • 4041 Answers
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
E03 error in toshiba e studio 207
Power-ON jam:
The paper is remaining on the
paper transport path when power is turned ON.
1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the MAIN board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are open circuited.
4) Replace the sensor.
5) Replace the MAIN board.
Mar 15, 2016 | Toshiba e-Studio 207 Copier
What is code error e03
Printers & Copiers
Code error E03
Nov 14, 2014 | Office Equipment & Supplies
Mp499 The paper tries to go thru but only one side pulls it and it goes sideways and gets jammed.
The feed wheels on the one side are either worn out or have some scrap paper stuck on them. Take a good look , after removing the paper tray, if it has one , inside the machine. It might be possible to turn the machine around and see into it from behind, if there is an access door on the back.
Aug 02, 2014 | Canon Office Equipment & Supplies
A 0 2 P flashing on my canon printer
Have you tried turning it off? If you haven't tried it after getting the paper jammed, then turn it off. Just make sure that the paper is removed.
After turning it off, unplug it from the wall outlet and from your computer. Press and hold the power button for 5-8 seconds so that you can drain the power completely.
Plug it back in the power outlet. Turn it on.
Plug it to your computer and check if you still have the same error. If the flashing lights still occur, make sure that all papers which are jammed are removed. There might be some small paper left inside your printer.
I hope this helps.
Carlo
Nov 21, 2012 | Canon Pixma MG3150 All-In-One Color...
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
HP psc 1310 - gave paper jam and print cartridge error. There was not paper jam and paper jam message went off. My son changed one of the print cartridges, although it still had ink in it. The error...
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Oct 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Paper jam that isn't
You could try a partial reset of the printer
Unplug the power cord
Reconnect power cord
When lights are flashing, press & hold On/Resume and PaperSize buttons
When only the On/Resume light is flashing, release both buttons
When On/Resume light is steady, reset is completed
Feb 21, 2009 | HP PSC 1210 All-In-One InkJet Printer
E3 error message
Dude,
E3 refers to Paper Jam :)
this may come in handy:
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
îäíàêî, äëÿ ôóíêöèé 4 è äàëåå åñòü ïðèìå÷àíèå : òîëüêî äëÿ àçèè.
à âîò â îïèñàíèè ôóíêöèè 3 åñòü : Reset except for the
followings:
- USB serial number
- Destination setting
- Waste ink counter ...
Turn it upside down and than check.....same error code or diff.
Any help, can buzz me nytime ...
Thnks.
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP240 All-In-One InkJet Printer Logo
713 people viewed this question
old marine
old marine
