I have the same model 2240 Vermont Castings Radiance Stove. My problem is the inspector needs to see the manual for it and it has a passive vent rather than a direct vent. I can't find the infor
2 Suggested Answers
  • 4736 Answers
SOURCE: i boughta vermont castings model
It the opening on the stove is on top of the stove, it's a 'B' vent. If the opening is in the back of the stove it's a "Direct Vent". However, some models have a connection on the back that's facing up,. A 90 degree elbow can be used to convert it to a horizontal run to enter an existing chimney, but then it must elbow up to connect to the pipe that is required to line the chimney. You should not just stop the pipe above the damper. It needs to run all the way to the top of the chimney, then have flashing seal the chimney's clay liner and a termination cap on the top.
here is a link to the Owners Manual/Installation Instructions for a Model 2600. It installs the same way as the 2610. http://homeappliance.manualsonline.com/mdownloads/62b85343-a800-4898-85a1-3d6d3c524259.pdf
Hope this helps you sort things out and do a proper installation.
Posted on Apr 18, 2011
Testimonial: "thanks"
My vermont castings radiance model 2600 lp gas heating stove starts fine then after a few minutes rear flame goes out and flames start coming out bottom of stove
Dangerous! Don't relight until you have qualified person inspect it after they actually take it apart to look for the problem.
Sounds like major gas leak or faulty gas valve. Don't take a chance on it. don-ohio
Jan 22, 2017 | Heating & Cooling
Rnv40 pilot goes out
Sounds like you need a new thermocouple. here is the link to the part
http://www.ibuyfireplaceparts.com/model/radiance-rnv40-vermont-castings-gas-b-vent-stove
Apr 09, 2013 | Grilling
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
Looking to purchase new or used log set for radiance vermont castings stove model 2600 log set # 500-2933
I have a log set that came out of a Radiance Vent Free Stove. Not
sure of the part numbers. If you are interested, email me at
alis4@yahoo.com.
Marty
Oct 17, 2011 | Grilling
I boughta vermont castings model # 2610 cast iron radiance franklin stove it came w/pipes .............is it a direct vent or a b vent..reason why i am asking is he gave me a "t" pipe w/ screen...
Apr 18, 2011 | Heating & Cooling
I bought a Vermont Casting Radiance Model 2240 Gas Stove 10 years ago. The fan makes a horrible noise. I have a manual, but the fan page says the fan is optional and page 1 is missing. Also page 2 is...
Finding an match to your Owners Manual is difficult at best. As, Vermont Castings has gone through 2 different corporate ownerships in 10 years. However, for the most part, their castings and the mechanics for the Radiance model have pretty much stayed the same. This gas stove was manufactured in a Vented and a more efficient Vent-Free model. The installation of the fan was different for each model. Since you didn't specify whether you have a Vented or Vent-free model have included the Owners Manual for both. Keep in mind, these manuals are for the stoves that currently being produced, but the installation is very similar. You will be removing the blower rather than installing it, so do everything in reverse.
Vented Model http://literature.mhsc.com/vermont_castings/manuals/30004967_RADVTCS_5.pdf
Vent-free Model http://literature.mhsc.com/vermont_castings/manual/30005056_Radiance_VF_5.pdf
If you need to replace the blower, you can purchase one from an authorized VC dealer in your area. To find one go to http://www.vermontcastings.com/contact.asp
Mr. Whaley, I hope this helps solve your problem.
Mar 21, 2011 | Heating & Cooling
I have a vermont castings natural gas stove Model # RFSDV34RFN. I need the owner's manual.
You can download the Owners Manual for your VC Radiance Direct Vent gas Log Stove from Vermont Castings website starting on it's Home page. www.vermontcastings.com . Then click on Brochures, Manuals & Spec Sheets.
Feb 15, 2011 | Heating & Cooling
Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
Dec 22, 2008 | Heating & Cooling
Heating & Cooling Logo
597 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
