I pod locked - Audio Players & Recorders
  • 7,482 Answers
Hi jacobdoe20
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Posted on Nov 03, 2012
How to open gas cap door 1990 mercedes 190e
If your locking pod on the door has given out you can pull the carpet back in the trunk and yank the linkage to the fuel door to open, but will most likely have to do this every time unless you repplace the vacuum pods as they work longer on the locking pposition that unlocking.
Jul 18, 2010 | 1990 Mercedes-Benz 190
Need to turn off i pod
Hold the lock and home button for 10 seconds, or hold the lock button after the iPod is unlocked and than slide the power tab that comes up over. Or let the iPod die.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 05, 2010 | Apple iPod MA446LL/A MP3 Player
240d mercedes. automatic door locks seldom work.
Very common. The rubber diaphrams and checkvalve o rings do not last forever, and they begin to leak. The most common one is the driver side's vacuum door lock valve. This one is activated when your key turns the lock and diverts the valve's vacuum, which activates the other door's plungers to open. This is the one to fix first, and it requires that you remove the inside door hardware and panel to reach it. Buy a new valve ahead of time so you don't have to take it apart again. Then try the system. If it works but still not well, then get ready to test the other vacuum pods: Trunk, gas cap, center dash (HVAC). The center dash pod is fairly common and a bit difficult to reach (I would go through the center dash' vent with one hand, and the removed glovebox with the other) to replace the center. Check the web for the detail on that one because it requires taking the pod apart while its still attached to its bracket under the dash) Not fun, but better than removing the entire dash. In the end, troublshooting - specially without a vacuum pump (you can get a hand held one from an autostore) - is tedious and is by trial and error and replacing the pods. But, either you do it, or be charged $75/hr and no gaurantee the leak can be found. New door valve is about $20 and the dash pod $25.
Feb 17, 2010 | 1983 Mercedes-Benz 300-Class
I pod is disable , unable to unlock using password
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
Sep 22, 2009 | Apple iPod touch
My i pod is lock and i dont know my code
Just hook it up to your computer and when itunes open,Click reset.
This will only work on the computer that the Ipod is setup on.
Feb 20, 2009 | Apple iPod touch
Ipod Nano stuck in locked mode
well plug your i pod into itunes and reset your i pod to factory default
Trust me I had the same problem
Sep 19, 2008 | Apple iPod nano
 Grubhead
Grubhead
