Question about Motorola Mobility H350 Wireless Headset
Listen to music on my phone using a motorola H350 bluetooth
I have a Blackjack 2 phone with a motorola h350 bluetooth that i am tring to listen to my music stored on my phone through the bluetooth. Can i listen to music on my phone using a a bluetooth.
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
I cannot connect my h350 headset to my phone how doi I do this
on your phone open your bluthooth section and(1) turn on bluetooth. then in the bluetooth options, (2)have your phone ready to search / find devices. (3)on the h350 press and hold the power button for about 5 seconds until the blue light comes on and stays on. it is now in paring mode. (4)tell ur phone to search for devices. your phone should find it. (5)then select the h350 on your phones found devices list. they will now pair. its possible a password will be requested, i believe the factory default password for the h350 is 1234. your phone password may be the same as your phone unlock code or your voicemail code.
time is limited you may have to do this a couple of times before they actually pair together.
Feb 19, 2010 | Motorola Mobility H350 Wireless Headset
Cant connect. What type of device is the Motorola h350?
Motorola H350 is a Bluetooth headset device. Free yourself from confining wires and immerse yourself in music with wireless Bluetooth stereo headphones! You can comfortably enjoy your favorite music without messing with annoying wires!
Jun 26, 2009 | Motorola Mobility Bluetooth Hands Free...
Want to remove Motoraola H350 Bluetooth from MOTORAZRV3T phone
Hi
Try going into paired devices or active devices and delete from there
Feb 20, 2009 | Motorola Mobility H350 Wireless Headset
Motorola H350 Bluetooth
because certain headsets have their own tone, no matter what tone you have set on your phone, you need to set it up in the options in the bluetooth headset settings in your phone.
Aug 31, 2008 | Motorola Mobility H350 Wireless Headset
Maual for Motorola H350 bluetooth headset
Hi - You can download the manual from the link underlined in blue below:
Motorola H350
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 18, 2008 | Motorola Mobility H350 Wireless Headset
Motorola h350
Enter your phone, go to connections go to bluetooth, device history if listed & delete listed bluetooth. Power of & restart. Re-setup your H350
Luck!
Please vote....
Jan 14, 2008 | Motorola Mobility H350 Wireless Headset
H350 pairing with Blackjack
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Sep 14, 2007 | Motorola Mobility H350 Wireless Headset
Pairing
Turn your Bluetooth on Go into your phone go to tools. Choose Bluetooth, then choose options go down to add new, then you will have 2 choices and choose searchand the devices will and and then the should work
Sep 11, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility H350 Wireless Headset Logo
155 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
