Question about HP dvd740i DVD±RW Dual Layer Burner
HP dvd740b won't write or pick up blank dvd's in drive
It has worked find for over a year, suddenly yesterday it wont recgonize SONY dvd+R or TDK dvd-R blank discs in drive. It WILL still read older discs ive burnt (movies, data). Is it possible that there are two spindles of NEW DVD-R discs that arent working with it.
* I did upgrade firmware, and drivers
  • 1 more comment
  • Quickfx PC Repair Jan 04, 2009
    * Tried setting it as Master and didn't hook up my other DVD/CD-RW
    After which it is now working with some memorex DVD+R's I just went and bought.
    * Will try to hook up my other combo drive, then update all drivers for entire pc not just the drive itself as first tried.
  • Anonymous Jan 08, 2009
    It no longer can see files on any DVD type. I have reinstalled XP Media center prior to this. I have found the firmware both an older version and the newest one hpdvd740b_HJ24.exe with no success. Followed directions to delete in hardware manager and regedit both upper and lower filters, no luck there either.
  • Quickfx PC Repair Mar 27, 2009
    Called HP to find out it has more than one laser inside, in fact multiple lasers. One can go bad while the others still work, I replaced the drive problem solved.
sandrew
  • 2961 Answers
SOURCE: problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Posted on Jun 13, 2007
  • 75 Answers
SOURCE: HP Lightscribe DVD 1040 dvd writer
try a firmware update
Posted on Jan 12, 2008
SOURCE: HP DVD 1040i
on the back of the hardware are jumpers
mine are located next to where the ribbon plugs in
there are 3 jumpers- like this : : :
the jumper must be on "cable" ( printed above post )
just move the jumper and reinstall
Now xp can find the 10401
I did it...it works
Posted on Jan 30, 2009
ButtFuzz
  • 463 Answers
SOURCE: dvd drive of my hp dv2000 is not working. it does
There is a screw (tiny machine screw) that holds the entire DVD/CD assembly in place. Usually this screw is located by looking on the bottom of the laptop and has a little picture of a cd embossed in the plastic. Sometimes this screw is under a "lid" such as the cover for the RAM or HDD, depending on how your laptop is engineereed.
Find this screw, unscrew it, set it aside and them pull entire cd/dvd assembly from computer. Replace the cd/dvd drive into the slot you pulled it out firmly and quickly.
Turn on and test reading of CD/DVD.
If love is found, replace screw holding asembly, etc.
If no love, replace CD/DVD drive.
Other sources of love:
correct cd/dvd driver.
remove/replace cd/dvd driver
update cd/dvd driver
Posted on Mar 04, 2009
SOURCE: hp dvd 1040i multi format dvd writer will read nothing!!
clean the laser lens
Posted on May 08, 2009
When I burn a dvd it won't work on my dvd player connected to my tv
First, can the resulting DVD be read and played on your computer? You should be able to play the DVD with PowerDVD on your computer.
If the disc can be played on your computer with PowerDVD, but not on your DVD player connected to your TV, then the problem is most likely the brand of blank DVD disc used. Many people do not realize that most DVD blanks sold in stores are not very good. Memorex is a particularly poor brand. Try using Sony, HP, or Verbatim, and make sure to get their "premium" rather than "value" brands. The best DVD blanks are made by Taiyo-Yuden (which is now owned by TDK) and can be purchased from Meritline or Supermediastore.
Jan 24, 2011 | CyberLink Power DVD DX 8.0 for PC
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
My light scribe drive will not recgonize blank media
your hp DVD there are so many cost of problem my be your DVD lens much better you buy other one.
Jul 09, 2009 | HP DVD 740VI 16X16 Dual Layer LightScribe...
HP dvd740b Internal Dual Layer DVD Burner w/ LightScribe Issues
Common problem associated with XP SP3. After updating to SP3 there's a probem with CD/DVD recognition. Here's the Microsoft patch below:
http://support.microsoft.com/kb/925196#fixit4me
Best of Luck!
Greg
May 18, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Unable to Write to HP dvd740b
the fix is usualy "upper and lower filter removal" easiest way is with filtercheck 4.6 at cdr-zone.com forums. click yes to all then reinstall your favorite burning app.
Oct 09, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Dirty Disk Problem with DVD+R Disks on SONY RDR-GX300?
I have used my Sony GX300 for a couple of years and love it. I prefer +R blanks. The only occasional problem is the media brand. It will not record Fuji 16X, but will record Fuji 4X, which are rare nowadays. I have used TDK 16X with success, but this week bought TDK "lightscribe" blanks, and the GX300 would not record with them.
Sony should provide an upgrade download for the GX300 but does not. On the internet I have been unable to find a list of suitable brands for this DVD recorder, so I have to take risks when shopping. Fortunately, all blanks can be used for my computer so my money is not really wasted.
It's October, 2009 and in Toronto there has been a shortage of DVD blanks for months. I've been told there will be lots available in December.
Sep 03, 2008 | Sony RDR-GX300 DVD Recorder
MY DVD DRIVE DOES NOT DETECT DVD
Time to replace the drive.
A good source is newegg.com
Sep 01, 2008 | LG GSA-H42N 18xDVD+-R, 12xDVD-RAM,...
TDK Cyclone Combo
What wonnt work? does it read CD's?
Mar 19, 2008 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
Sony dru-810a dvd rw dual layer burner
try using TDK disks i rarely have a problem with them try doing a drive test using a blank dvd
Nov 01, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
HP dvd740i DVD±RW Dual Layer Burner Logo
571 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
