Question about Hohner B2AV-CRS Headless Left Handed 5 String Bass with Licensed by Steinberger Bridge Flame Maple Cherry Sunburst
Put new string in a hohner steinberger bass very hard to turn tuner to pitch
Right handed
    New Friend:
You have stripped the threads on the string retainer part of the bridge adjusters. You will have to have it rethreaded with helicoils or buy a replacement which is $39
Posted on Dec 26, 2012
  • garyrudd
    garyrudd Dec 26, 2012
How to adjust the pickup on a bass guitiar
It's a balancing act between volume and string pull. Generally I raise the treble pickup as close to the strings as possible without the strings hitting it while playing hard. Then play sustained notes and see if the pitch wavers from magnet pull. If so, lower the pickup a bit until the waver stops. Then ring up the bass pickup until the output matches the treble pickup. If that doesn't cause waver, your set. If it does, lower the bass pickup until it stops.
Feb 17, 2018 | Music
I tune my guitars at 400 using a clip on tuner,which I believe is concert pitch I've recently bought a 5 string blue grass banjo .I set tuner to c mode to tune banjo is this correct
Actually, concert pitch is A=440 rather than A=400. Normally a 5 string banjo is tuned G (octave) D G B D though many variations exist.
Feb 20, 2015 | Ovation Music
How to tune 12 string guitar with ga40
Just use as if you are doing a 6 string ( instructions in the pack ) only play one string in each group at a time. The thinner string in a pair should be exactly one octave higher than the thicker string. Strings of the same thickness are in unison ( sound the same pitch )
Nov 15, 2014 | Korg Ga40 Guitar Bass Tuner W Batteries
Tuner Won't Acknowledge Sound
Before turning the unit on, press the calib/batt button to check the battery condition.
The Fender AG6 only responds when the strings pitch is within a certain frequency range. If the guitars tuning is not within that range or if your installing new strings, first connect the guitar to the AG6 with a cord that you know to be in good working condition and turn the AG6 on. Then starting with the low E string (the thickest one), loosen the tuning peg to a point well below the standard tuning for that string. Then slowly tighten the peg as you strike the string repeatedly. When the strings frequency, comes within range you will see the 6E light glow and the needle will begin to deflect. When the needle reaches zero it is in tune. Do the remainder of the strings the same way then go back and recheck each a second time. If you have a tuning fork, you can use it to tune by ear then re-tune and maintain it with the AG6
Remember to always stretch then re-tune new strings several times.
If the AG6 does not respond even after checking the condition of the battery and the cord that connects the guitar to the tuner, the problem could be inside the AG6 with a bad connection on the board. Try moving the cord as you strike a string that you know is close to being in tune. Again a tuning fork would be helpful.
~DrewWatk
Jun 10, 2013 | Fender AG6 Automatic Guitar Tuner
Make my bass strings feel lose
Ask for lite gauge steal strings
Apr 29, 2013 | Music
Ive got a dean vedetta guitar with floyd rose pickup... every time i tune it, it goes off in a while... also my string levels are very high which makes it difficult to play... i dont have much knowledge...
Some tuners have a weird mode that one presses the button once and the tuner will pass the audio until it times out, then tuner and audio stop. Two presses kills audio while tuner works for a time period and then goes dead. A third press enables audio to pass for normal playing. These are confusing compared to other type built in tuners. If you have one of these read the CONFUSING instructions carefully...
May 07, 2011 | Dean Vendetta XM Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
Gibson Les Paul wont stay in tune
That's the problem; you're using light gauge guitar strings. Chances are that if you are not used to playing strings that light, you're fretting hand will hit the strings with more force than is neccesary to fret them, thereby forcing them out of tune. You can solve this problem by adding more winds around the string post (three or more winds should do it), or you can switch to a heavier gauge of string.
If they're true locking tuners, they should have a notch on the back of the gear housing that you turn with a nickel to engage the locking mechanism once tuning has been established.
Also; check the intonation of the guitar itself on an electronic tuner. If it tunes right but sounds out of tune when played, this is an intonation issue, and can be solved by adjusting a small set screw that moves the individual saddle back and forth in the tune-o-matic style bridge. You can check this by tuning the string to the correct note, then playing the same string at the 12th fret and checking it against your tuner. If it rings in true, you're fine, if it comes up flat or sharp, every note on the fretboard is going to be off by that much, and you'll have to adjust accordingly (turn the screw to the right to add length and lower a sharp note, turn the screw to the left to subtract length and raise a flat note, if I remember right).
Hope that helps.
May 12, 2009 | Gibson Music
No instructions for a yamaha erg 121 c electric guitar
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Feb 05, 2009 | Yamaha Electric Guitar
Hohner B2AV-CRS Headless Left Handed 5 String Bass with Licensed by Steinberger Bridge Flame Maple Cherry Sunburst Logo
97 people viewed this question
Top Hohner Music Experts
Michial Gueffroy
rhodesworks
Tom Chichester
Are you a Hohner Music Expert? Answer questions, earn points and help others
