My dell inspiron e1705 wont charge its plugged in but not chargeing what do i do
    Problem Solver:
  • 7 Answers
Get a multi-meter and check for DC voltage at the connector the plugs into the computer. You can remove the battery and clean the contacts with a pencil eraser. If that doesn't work check your settings in the control panel under battery.
Posted on Nov 02, 2012
  • 11 Answers
SOURCE: Dell e1705 will not charge battery any longer
The problem with your laptop unfourtunately is not anything you can simply waive your wallet at, There area on the laptop where you plug in the power Adapter has a very small connector on the inside, this connector because of the nature of the cable and being pulled around and adjusted constantly causes the solder that hold the DC connection in place becomes damaged, sometimes if held in the right position it will charge, but this will only work for so long as the connector becomes more damaged by doing so. Your options are to A.) take the laptop to someone who can solder it back on (literally takes 25-30 minutes) but finding people who are willing to do it is not so easy, i recommend smaller computer shops with Uber nerds (look for the dude with the calculator watch) Option B.) this actually is something that dell covers under warranty as its not damage done by you directly, the damage is done with general use. I would at least try to contact them to see where you are with your warranty. C.) Call Dell's Spare Parts department in the event that your laptop is not in warranty and purchase a motherboard replacement ( seems extreme but its the only way to replace that proprietary connector without soldering it back on ). There is one more problem that could cause this, and that is that the motherboard in your computer has actually started to fail and is not getting the power to the battery, in which case you Have to contact dell, or find someone who will replace the motherboard for you most likely at an hourly rate. if this is the case Go hunting for Dell E1705's with broken LCD's for sale, you will save your self a ton of money, and swapping the motherboards out is really not that difficult, any computer repair place should have the ability.
This solution addresses all the known problems I've seen and should get you on the right path.
Good luck! Stay Classy :)
Posted on Mar 28, 2009
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
  • 66 Answers
SOURCE: Dell inspiron E1705 laptop to factory settings
System restore: Click Start, Programs, Accessories, System Tools, System Restore. Follow all prompts.
Remove printer: Click Start, Control Panel, Printers. Right-click Printer you want removed, then left-click "Delete".
If you restore the computer to a point in time BEFORE you installed the printer, you can skip doing the remove printer option I wrote above.
Those fixes can be done one-handed (with your mouse).
You posted in the free area, so there is no charge.
Posted on Feb 13, 2009
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
Posted on Jul 31, 2009
Geekman
  • 32281 Answers
SOURCE: inspiron 1420 dell says plugged in not charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Feb 22, 2010
My dell inspiron E1705 laptop is not charging but my adaptor is working fine. What should i do?
If you're sure the charger adapter is OK; replace the battery in the laptop. It is weak. Does not hold the charge.
Jul 06, 2016 | Dell Computers & Internet
Won't power on
Hi friends,
please check the dc adapter voltage,And battery also.
Ensure the adapter light is gong on, if ok condition, please measure the voltage.
Voltage will be E1705 DC Car Adapter (20V/6A 120Watts) check it.If not work please purchase from
http://www.amazon.com/Adapter-Inspiron-Latitude-Precision-Workstation/dp/B002BH8XAO
http://www.amazon.com/Dell-INSPIRON-Latitude-PA-10-Original/dp/B0034JWXBI
For battery
http://www.amazon.com/Lithium-Ion-battery-Dell-Inspiron-E1505/dp/B001E41PHI
Hope it will help you.
Dec 17, 2010 | Dell Inspiron E1705 Notebook
Dell Inspiron E1705 battery light flashes 4 amber lights, then 1 green. The battery seems to charge.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Dec 29, 2009 | Dell Inspiron E1705 Notebook
I am having the same problem
The bios can only be flashed if you have more than 10% battery charge. check if you have any other AC adapter. is the battery does not charge with another adapter then it could be a battery or motherboard fault. Try another good known battery, If even a good known battery fails to charge then its a motherboard issue. Call technical support and get the motherboard replaced.
Rate if useful.
Aug 10, 2009 | Dell Inspiron E1705 Notebook
I just replaced the battery for a Dell Inspiron 1150. Does the battery need to charge? I'm getting a yellow light when I try to turn it on. I ordered the battery when the computer wouldn't boot. I wasn't...
Batteries and battery packs are generally given only a superficial charge by the factory to verify cell and assembly integrity so nearly all must receive a full charge before their capacity is reached.
Only once have I seen carded Li-ion cells (AAs) offered as fully charged so they could be used to replace dead cells in (for example) a camera.
Jul 05, 2009 | Dell Inspiron E1705 Notebook
Flashing battery light orange three times then one green?
Try charging your battery for about 30mins, light orange still came up it means your battery is faulty. To confirm, take out your battery and plug in power. If it turned on, i strongly suspected it's a battery faulty. You need to replace it.
May 17, 2009 | Dell Inspiron E1705 Notebook
Laptop wont turn on even with new battery
new batteries should be charged before they are used.charge the new battery for six hours.
make sure that the battery is placed into its slot correcctly.
Dec 03, 2008 | Dell Inspiron E1705 Notebook
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
