Question about Dell Inspiron 1420 Notebook
My Dell Inspiron 1420 screen goes black
The boot process starts up. The machine actually boots, but it never displays anything on the LCD screen. I have just hooked the computer up to a monitor, while the video is not sized or set properly, it does display on the monitor's screen.
  • Dell Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Nov 03, 2012
Nowuser
  • 56 Answers
SOURCE: Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Posted on Jan 03, 2008
mewms_14904
  • 1027 Answers
SOURCE: Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
Posted on May 29, 2008
  • 53 Answers
SOURCE: Trying to hook up a TV to my Dell inspiron 1420 PC
that actually isnt a true svideo port. it does output video, but it needs a converter that dell sells for about 30 bucks (ebay is cheaper). it plugs directly into the "s-video" port on the computer and splits it off into both an svideo connection and an rca connection.
Posted on Jun 10, 2009
bunnydawg
  • 5158 Answers
SOURCE: Dell Inspiron 1420 will no longer boot
you need to enter setup by tapping one of the f keys or the delete key. i'm not sure which it is for this model. when you enter the bios setup change the boot order to boot to the dvd first. hit f10 and save the change then reboot with your install disk in the drive. it should start installing.
Posted on Sep 06, 2009
tech4allmen
  • 666 Answers
SOURCE: When I boot up my Dell Inspiron 6400 I can see the
Obviously the issue is with the computer's inverter cable. It's not the LCD issue at all.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
Posted on Jun 27, 2011
Testimonial: "I will buy the part I need to make it work. It was fast and easy. Thanks for your help."
"error loading operating system" message on dell inspiron 1420 laptop
only way to bypass this is use a recovery disk to boot from and then perhaps the issue will manifest itself
otherwise, it's the dreaded re format step
May 22, 2012 | Dell Computers & Internet
I have a Dell Inspiron 1420 laptop. I left it running overnight and when I checked in the morning the screen was moving up and down. I tried playing videos in full screen and it does, too. It seems as...
boot in the safe mode, see if issue still occurs (F8 at boot) if it does, then likely there is a problem with the Video Card or the LCD itself, I'm leaning toward the video card.
Try flashing the bios to current and installing the most current video driver, see if anything changes.
Sep 05, 2010 | Dell Inspiron 1420 Notebook
My dell inspiron 1420 wont lighten up the screen is black though i can see my desktop
Likely the backlight but those are quite hard to replace. I would try the inverter board 1st as they are cheap and often the problem. You should look 1st at the inverter board to see if there are any cracked chips. Otherwise I would suggest a new/used LCD. BTW you can narrow down the issue by unplugging the cable from the MB to the LCD and or inverter board and try to boot with an external monitor connected. This rules out the issue being on the MB
Alex
Apr 29, 2010 | Dell Inspiron 1420 Notebook
The theme chane does not change anything. the error is right from the booting....the welcome screen onwards the monitor config is out?????
you mentioned monitor. this is a laptop right? so monitor is the lcd correct? now when you turned on the laptop and sees dell logo it means display is ok. after windows logo or after you type in your password display goes black? try startup repair first. using the windows media.
Sep 20, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Sep 06, 2009 | Dell Inspiron 1420 Notebook
A line ppears on my dell inspiron 1420
A thin line across teh screen is an indicator that the LCD is bad. There's not anything short of replacing the screen that will resolve this issue.
Aug 31, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell insiron 1525
My father had a similar problem with the HP he has. Basically, what has happened is the actual script that controls where the boot sector is located is corrupt.
Boot with your first recovery disk and try to fix the issue. If this doesn't work, then you'll have to reinstall.
Jul 25, 2009 | Dell Inspiron 1420 Notebook
Dell inspiron 1420 startup error
You need to cheat a little. First try to boot into safe mode by pressing the f8 key as soon as you hit the power (and keeping your fingers crossed on the other hand that it notices your doing this). Before you get too depressed just try booting into safe mode and then reboot normally. That may be all it take to fix it. Try this a few times before getting into the more serious fixes.
If you can get into safe mode you can simply copy your files off to a usb data drive. Those will still work. You may be able to use the wired network card if you select safe mode with network access. But don't count on that. The cd/dvd will not work so you can't burn it to disk. A flash drive will work on the usb while a external hard drive that connect via usb usually won't as it needs drivers.
The other way is to boot using a bootable cd. If you can get a vista install cd you can install over the top of your existing windows and retain your settings. If you don't know where everything is then you need to be a bit creative and use something like the demo Ubuntu cd that boots into a windows like operating system that will allow you to copy stuff over the network to the usb drive or the network.
If you have a friend with the right laptop or desktop you can take the drive out and set it up as a second drive. When they boot normally they then can see your drive and just copy burn or move your stuff. This is what I do in the shop when the existing system is too messed up to work with. There may be the odd thing you won't get access to but you should get most of it.
Jul 09, 2009 | Dell Inspiron 1420 Laptop
Dell Inspiron 1420 Factory Setting Recovery
back up all your files first because everything will be wiped out.
Turn on machine, Put the recovery cd on the cd rom drive, before it boots to windows hit the F1 to go into bios, on the startup set the cd rom the primary to boot machine on cd then follow the instructions from there..
Jun 30, 2009 | Dell Inspiron 1501 Notebook
Will not boot up!
Windows has probably become corrupted,,,try using you restore cd,,,or starting in safe mode.
Dec 23, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
158 people viewed this question
Alun Cox
