Edirol UA-4FX External Sound System Logo
Posted on Jan 04, 2009
Recording and hearing
I bought Edirol UA 4FX 3 months ago. Since then I couldn't record anything. Seemingly I am doing something wrong. I have Cakewalk, Sonar and Nuendo for recording.
Can you explain simply how to use the equipment, I just want to record my songs with my guitar.
Best regards
Kenan Akbayram
5 Related Answers
A
Anonymous
  • Posted on Sep 22, 2007
SOURCE: SONAR LE NO AUDIO
make sure, if you are using windows you have the right sound card settings (control panel->audio and sound devices or however) as mentioned in the manual. Also, using sonar LE make sure to have correct settings (options->audio settings). i had trouble with playback too but now everything's working fine. in my sonar settings i use the ASIO driver mode, and mark 'share with other programs'. make sure the right sound card is selected too (options->audio->drivers) and then it sould appear in the advanced window (as for the playback and the record timing master). other possible solutions might be in the options-> midi devices window, though i doubt that. I hope this can be helpfull. Good luck! btw, any solutions on how to NOT get the registration window on the startup?
Anonymous
  • 1067 Answers
  • Posted on Jan 28, 2008
SOURCE: Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
A
Anonymous
  • Posted on Jul 31, 2008
SOURCE: Edirol UA-4FX : No Midi output sound: OK with 1/4 plug audio/guitar in
he's wrong you need to change your wdm driver to asio 4 all!
Anonymous
  • 3422 Answers
  • Posted on Sep 04, 2008
SOURCE: Synthogy Ivory italian Grand won't play with Edirol UA-4FX sound card
HI,
You will need to download the drivers for it.
Anonymous
  • Posted on Sep 08, 2008
SOURCE: My Edirol UA-25 suddenly is not working with Nuendo
Hey, if you're in the UK you can ring tech support on 0208 747 5949 - they're really good.
Have you got the advance switch set to ON on the back of the device?
LC (UK)
Can't Record and Only hearing playback via laptop.
Check you XP machine for SP3, go into the sound manager and make sure that the input your using is not muted and set as default.
http://www.ejoysoft.com/images/mixer.gif
3answers
Microphone connection
you just look whether you missed out any connection while shifting ........
1helpful
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
2answers
Recordin audio problems (drop out)
cheak msconfig start ups eating ram that needs alot ram be nice to add 1 gb more run cc cleaner.com tool get junk out update your software form webite fl latest flash adobe shockwave and java run spyware clean up close out all other programs when u work in studio program
Recording Device Not Listed
You need to install the driver accordingly, When you buy the product it comes with installation Disk. If you dont have it now still you have solution simply download the driver from the manufacturer's website
Here is the link
http://www.rolandus.com/products/productdetails.aspx?ObjectId=758&ParentId=114#
Good Luck
Problem with guitar
1.make sure the guitar/mic switch is pointed to the guitar side. increase the guitar/mic level. increase the output level. 2.another thing you can do is check the "sound and audio devices" to see if everything is set to Edirol UA-4FX. If everything isnt, fix it so that it does. and remember to disable your computers stock sound card. Edirol UA-4FX is your new sound card from now on. 3. if thats not the case, try reinstalling the drivers. 4. If all of the above fail, you probably have a loose connection/ bad wiring in the guitar/mic 1/4" input. you can choose to open up the device and solder that yourself and possibly lose your warranty or have the entire unit replaced. Hope I helped! good luck!
1helpful
2answers
Edirol UA-101
DOWNLOAD THE LATEST EDIROL DRIVERS AND INSTALL ...
Top Edirol Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
