Question about Pool & Spa
Loud pump seems like this pump is too loud.
  • 32,281 Answers
You could have a worn pump bearing.
Posted on Nov 03, 2012
Grundfos MQ3-35 hums loudly and does not pump. Alarm light does not go on. Pump seems "happy" but when a tap opens and the pump turns on, there is no boost in pressure and the pump just hums loudly......
Pump probably runs dry, try to fill up the pump with water a few times and see what it gives. If the pump heats up then the rotor is turning but no water moves, pressure is not building up. Pressure switch is maybe faulty. If you have the possibility to connect a pressure gauge after the dicharge you can see if the pressure is building up or not.
Nov 02, 2013 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
Engine making loud sound when attempting to start.
Diesel or Petrol?
Any warning lights on on the dash?
Oil pump working ok?
Check your timing belt?
Dec 04, 2012 | Cars & Trucks
I have this pool pump Jandy Stealth SHPF2.0 that started making loud noises. I took the Diffuser and Impeller out, checked the main shaft for any play, or any derby in the impeller, parts look...
you have posted your question under category "chain saws". Please repost under the pools and spas category so that the correct expert can assist you.
Dec 28, 2010 | Garden
Loud buzzing sound began on start up
It could be several things but the most likely are: Something is spinning around with the motor shaft. Unplug the motor and "blast" water through the vent holes to clear debris. Let it dry completely before returning to service. Something could be caught in the impeller. Remove the front end and check. Squeals, loud hums, heat and vibration are indications of bad bearings.
Apr 17, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Loud water pump
there is the possibility there is trash caught in the impeller that is causing noisy operation.
Other than that, sometimes the pumps will run loud. Its usually a early sign of motor failure. Not much you can do there.
I would recommend you order a new pump and have it at least on standby. And be prepared, Hoshi is proud of their parts and it shows in the price.
In short, if theres nothing caught anywhere, let it roll til it dies and then replace it.
Jan 20, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Faint to loud humming noise while driving and turning...
Could be either a loose belt or you are low on power steering fluid,or the power steering pump could just be worn out.
Aug 20, 2009 | 2006 Chevrolet HHR
Air compressor not working, campbell, hausfield turns on but doesn't make loud noise it used to seems like it is not kicking in. It just sounds like a loud vacuum cleaner. Campbell Hausfeld WL6501 13...
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Apr 11, 2009 | Campbell Hausfeld Air Tools & Compressors
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
Fuel pump is loud and seems like engine is starved for fuel.
If its loud it might simply be a mounting problem. Other posibility is that the fuel filter badly needs replaced causing extra load on the pump and the suggested lack of fuel.
Dec 12, 2008 | 2005 Rolls Royce Rolls Royce Silver Spur
Pool & Spa Logo
21 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
