Question about Black Diamond Diamond Sprinter Headlamp Diamond
My black diamond headlamp will not charge - Black Diamond Diamond Sprinter Headlamp Diamond
No. Where can I order a battery pack?
from a battery shop
from the manufacturer on line
from e-bay
Oct 06, 2015 | Black Diamond Apollo Lantern
Battery Packs available? Where.
where di you buy the lantern? that is where I would look first .
HOW DO I CHANGE THE BATTERY
Any idea what model of headlamp you have?
http://blackdiamondequipment.com/en/faqs.html
Call: (800) 775-5552
Monday - Friday 8am-5pm, Mountain Time
Email: orders@bdel.com
Fax: (801) 278-5533
If you're in Europe and have a question, you can reach us at Black Diamond Europe by sending an email to climb@blackdiamond.eu. You can also reach our European office via phone or letter:
Black Diamond Equipment AG
Christoph Merian Ring 7
4153 Reinach, Switzerland
p: +41/61 564 33 33
f: +41/61 564 33 34
Oct 22, 2014 | Black Diamond Sport & Outdoor - Others
Can't open up to replace battery on headlamp
aspen643-
Look for a slot on the top. There will be a gray tab in it that must be pushed in while gently prying apart the two halves of the headlamp.
Hope this helps.
Regards,
DIYpro
May 05, 2011 | Black Diamond Equipment 620593 CHILI...
Where can I purchase replacement Black Diamond Bright Bulbs?
GearX.com sells them for $6.50. Hope this helps ! Matthew
Jan 20, 2011 | Black Diamond Bright Bulb
Problem is not charging
First you guys need to know that the HTC does not charge if the ROM is inconplete/damaged .
And.....
If your battery is really dead there is no initial power on the internal battery to manage the chargement.
So ... resolution.
Fist way .
If you know any one that may have an other HTC Diamond you need to swamp batteries so the good Diamond that has the internal bat ok and charge it there.
Second way . this one i did it my self .
Go to a Local ChinaMan store and buy a multimeter and a regular Universal Adapter.
Heres how it hoes ...
Use the Multimeter do figure out the polarity pin's on the battery ex: + and - .
remove / cut one of the plug's from the Universal transformer and also tag the polarity.
set the voltage to be close to 5 V - 1 Amp .
Conect the cuted wire from the Univ. Adapter to the Diamond Battery respecting the polarity.
Leave it for a wile..... ( Probably up to 1 hour but chec from time to time tme battery temperature and if possible a reading on the bat voltage levels.)
Done!
Put the battery bat and boot your diamond or turn on to boot loader.
**** Attention if you don't have more than 50% of the bat charge compleated you wont be able to flash your phone****
Jan 14, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
Low beam of one headlamp not working. Do I need new bulb or other possible cause? 50cc chinese scooter. thx!
With all bulbs on this lamp being LED the fault has to be the individual bulb. Unfortunately these are not repairable or replacable. Is the lamp still within warranty? If so I'd get it back to BD.
Hope this helps..
Aug 14, 2009 | Black Diamond Icon Headlamp
Accidentally dropped HTC diamond - Display blackout
zohail, i have similar prblem and would liek to give it a go myself. could you provode further instruction?
Thanks in advance
Alex
Jun 01, 2009 | HTC Touch Diamond Smartphone
You want to sell it? mail me at leon.tiger2@gmail.com
Apr 13, 2009 | HTC Touch Diamond Smartphone
Black Diamond Diamond Sprinter Headlamp Diamond Logo
76 people viewed this question
Top Black Diamond Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black Diamond Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
