Question about LG DLEX2650W 7.3 cu ft Electric SteamDryer
How do i remove the front panel on my LG dryer model DLEX2650W?
I was trying to switch the door to the other side and when I removed the latch, the inside half of it fell down into the front panel.
  • 38 Answers
Most likley there is screws on the bottoms and or there are screws on the top back and the lid slides out then you will have to remoe the panel and then the door
Posted on Nov 02, 2012
Need to remove front panel of dle0442w to get to heat limit switch
unplug the dryer,remove the top panel,remove the control panel,usually a couple of screws on the top right and left side,when you get the control panel off there are like 4 screws on the top front panel then open the door and remove 2 more screws,disconnect door switch.go here this will help you out i'm trying to go by memory and it's harder to remember how to do it,when i'm in front of it i can pull it apart no problem but this should help you out.
http://www.youtube.com/watch?v=RvbJn61d9hQ
Nov 08, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Ok, I have an LG Dryer, model # DLE 0442w. It is making a horrible vibrating noise. I believe it has something to do with the venting system. I have tried just about everything to get the front of my dryer...
Use a flat screwdriver and place it in the gap between the front panel and the top panel about 4" from the sides. Push in to unlock the clip holding the top panel to the front panel. There is one on each side. Lift the top up and remove the 2 screws holding the front panel on top. Now open the door and remove the 2 screws holding the front panel to the filter screen insert. Pull the whole panel out and disconnect the wire connection to the door switch. Lift the entire front panel up and out and you will have access to the blower wheel on the bottom left.
Good luck.
Jul 11, 2011 | LG DLE0442 Electric Dryer
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
A piece of clothing got sucked down the lint vent and now the dryer makes a loud squeeling noise. I need to know how to disassemble the dryer to get to the piece of clothing
LG dryer disasembly notes:
To disassemble remove the top first by removing screws in rear. To take off the control remove to screw on each side of the back. All connectors are color coded. Cannot screw up reassemble.Lift control out and up. Control board has 4 screws and is replaced as a unit. Keep the selector knob.
Removing and reversing the door
Remove the screws from opposite side and then remove the latch pull out the latch no wires are there. Take the door off and reverse it then replace the latch and shorter screws for extra holes.
Remove the front:
Disconnect the dryer light and door switch wires. Move harness out yer way. Remove 2 screws at the base of the door opening and 4 screws along the top. Tip the panel to the front and lifts off. Next remove the top bracket 2 screws each end. Lift brace up and off.
To remove the shroud/panel 4 screws are removed and lifted up and pulled forward. Disconnect the wire to the humidity sensor.
Remove the belt from idler and yank the drum out. (The belt goes under the tensioner then over the pulley then release it and the spring holds everythang in place like a DOT dryer.) The grooved/ribbed surface goes to the tub side.
LG Dryer
Jan 30, 2011 | LG DLEX3001P Dryer
My dryer does dry my clothes... thier is not hot air coming out what could be worng?
Could be the element the safety's or some sort of sensor. To disassemble remove the top first by removing screws in rear. To take off the control remove to screw on each side of the back. All connectors are color coded. Cannot screw up reassemble.Lift control out and up. Control board has 4 screws and is replaced as a unit. Keep the selector knob.
Remove the front:
Remove the belt from idler and yank the drum out. (The belt goes under the tensioner then over the pulley then release it and the spring holds everythang in place like a DOT dryer.) The grooved/ribbed surface goes to the tub side. themobilian_672.jpg
LG dryer service Manual
Jan 04, 2011 | Kenmore Elite HE4 Electric Dryer
I'm trying to replace the door catch on the front panel of a Whirlpool Dryer model GEW9868KQ1. I've replace the piece on the door but can't figure out how to get the front panel off.
Hi, You shouldn't have to remove the front panel. Just squeeze the latch hard enough to remove it. I hope this helps. Please let me know if I can be of any more assistance.
Thanks
Vic
May 16, 2009 | Dryers
Heater element-how do you change?
take puttyknife put between top and front panels about two to three inches from sides one at a time push in to release tab top will flip up two screws at top front corners pull front panel toward you unplug door switch and remove front panel then take four screws from roller and duct panel and remove from latches and unplug conector underneath set roller panel aside remove belt from will walk you thrugh the rest
Feb 23, 2009 | LG DLE2532W Electric Dryer
How do you reverse the door on a front load dryer. Model #GLE02152ES1
Remove the hinges from the dryer and then unscrew them from the door. Remove the 4 screws on the opposite side of the door so the inner and outer door panel detach. You will also have to remove 3 phillips head screws that hold the door handle to the panel so you can flip it, because top and bottom are not symmetrical. One of the 3 is hidden under the handle, you will see it when the other 2 are off. Rotate the handle and reassemble handle and inner door panel. Put the hinges back on opposite side and also switch the door latch. PS, one glitch is that the light cutoff switch is on the right side, so the door has to seat well to turn it off.
Jul 13, 2008 | Frigidaire Dryers
Zanussi ZDC67550 Dryer, door swing change?
Hi
just reversed the doors in 15-20 mins. It worked for me. You do need to be a competent DIYer to do this.
If in doubt, do now't. Get in an engineer
Disconnect from mains (obviously)
Remove top using 7mm nut driver/spanner
Remove 2 cross-head screws holding the door - Door will come away from dryer.
Remove 2 cross-head screws holding the white top and bottom blanking plates
pull out the switch blanking plate
Locate the PINK wires connecting the switch/latch mechanism inside the dryer at the top. This will be taped to a blue wire.
Unscrew the 2 smaller cross-head screws holding the latch/switch assembly whilst holding the pink wire to stop the mechanism dropping inside the dryer.
Pull up the latch mechanism and unravel the black tape holding it to the blue wire.
Drop the latch assembly down the lefthand side of the dryer and refit using the 2 small cross-head screws.
Retape to the blue wier and feed the PINK wires through the plastic retainers.
Fit the white blanking plates to the RIGHT handside of the door opening.
Swap the hinges and the switch latch on the door (don't lose the spring !!!, refitting the hinge blanking plates(ease these out with a small flathead screwdriver covered witha bit of insulating tape to avoid damage.)
Fit the door using the 2 cross-head screws you have left
Refit the top.
Connect to the mains and switch on to the sound of £80 you have just saved yourself !!
Electricity kills Be careful
Oct 03, 2007 | Whirlpool GEW9250P Electric Dryer
LG DLEX2650W 7.3 cu ft Electric SteamDryer Logo
423 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
