Question about Mooii PhotoScape
I am trying to edit the pics bt its showing an error message, the file dos not exist or is unreadable... Y??
I connect my apello m300 to laptop.but show this error in that time."The file or directory is corrupted and unreadable" why show this messege
Compare the "corrupted message" to a child with a pen writing all over the "table of contents" of a book. Some of the entries in that table of contents have become unreadable.
So, the "logical-integrity" of the disk-drive has been compromised, either by a software error (Windows writing files to the wrong place on the disk-drive) or by a hardware (Windows tried to write files to the correct place, but that part of the disk-drive cannot reliably be accurately recorded).
Apr 09, 2015 | Imation Apollo Expert M300 Hard Drive
Msg Opening Prob. N70
As you said You deleted SOME SYSTEM FILES
  • Try to avoid editing in System files if YOU R NOT SURE ABOUT THE FILE
Anyway you might be deleted sys file supporting to open Msg....
Now Do following....
  • Press CALL button
  • Press *(Star)
  • Press 3
  • Press Power ON
HOLD IT until it appears/ Blinks Nokia TWICE....Or for few minutes....
YOU ARE DONE.......ENJOYYYYYYYYYYYYYY........!!!!!
AM HERE too
Mar 28, 2010 | Nokia N70 Cellular Phone
I need to retrieve photos which are 'missing', not deleted by me.
You can download the Setup Sheet and User Manual free from here
If I was helpful, Kindly do Rate! Regards, Waqar.
Sep 10, 2009 | Sony Ericsson D750i Cellular Phone
Error formatting pendrive
your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes and scan your whole system as well as your pendrive
I
Apr 18, 2009 | Transcend T.sonic 612 MP3 Player
Maxtor 3200 error message
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If it doesn't make any unusual sounds and doesn't show up in BIOS - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.  if it is recognized with full capacity and only files are unreadable - try to scan it with demo version of some software like R-Studio or GetDataBack.
Dec 30, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't open HDD drive
Hi
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
This won't do any harm, it will fix errors on the disk and try to recover data from bad sectors. It might not solve the problem but it's worth a try. Jyo
Jun 19, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My Nikon Coolpix 2100 Lexar starter memory card has become unreadable
It sounds like your Dazzle is not compatible with the sandisk. Maybe the Sandisk CF UltraII card have a new update software in it.
Artgirlny
Jun 13, 2008 | Nikon Coolpix 2100 Digital Camera
Error: P-1
I had this problem on a Fusic (LX-550). The error occurs because a picture mail is corrupted that you're currently trying to preview (inbox). The Fusic inbox shows 3 pic mails at a time. If one of the three is bad, you'll get that error. If the bad pic mail is the most recent in the inbox, then send 3 pic mails to yourself to bump the bad one to number 4. This should allow you to get to your inbox without the error, although you still have to avoid the bad pic mail page(move up in the inbox to see you're oldest mail). Sending pic mails to yourself one at a time is one method of narrowing down the bad pic mail. The permanent fix is to install bitpim, edit->detect phone, view->view file system, navigate to /EPM/MediaStore/MessageStore and delete the offending pic mail. The file name with the highest number is probably most recent. Right click on the file and perform a hex dump to read the message time stamp. Do a backup first and view the hexdump to verify you're deleting a pic mail file. Good luck!
-Joe
Dec 15, 2007 | Cell Phones
Computers & Internet Logo
118 people viewed this question
Top Mooii Computers & Internet Experts
David Payne
David Payne
Are you a Mooii Computer and Internet Expert? Answer questions, earn points and help others
