Question about Kenmore Refrigerators
Kenmore elite 75053
Cleaning stainless steel
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Kenmore Elite refrigerator problem
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST (or may have a ADC)
Start with the timer. (if it has a ADC it will not apply) It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
Posted on Aug 31, 2008
bozcro
  • 867 Answers
SOURCE: I have a Kenmore elite
try liquid metal polish, make sure you only wipe in direction of grain, never across
Posted on Sep 10, 2009
  • 1456 Answers
SOURCE: I have a BLACK
Hello
You will be needing a scratch be gone kit.
Assess the damage. Determine if this is a deep scratch or a surface scratch, by running your finger across it. If you can actually feel the indentation, you have a deep scratch, gouge or ding. With clamps, carefully hold a small piece of dry ice over the gouged area. Hopefully,it will pop out, and not be as noticeable. Then you can treat it in the same way other scratched areas are treated in the steps below.
Use an abrasive pad from the Scratch-B-Gone kit to repair scuffs, light scratches and even deep scratches. The kit has 4 different abrasive pads and instructions to tell you which one to use depending on the severity of the scratches and scuffs. Otherwise, go to an automotive shop and buy different fine grades of sandpaper.
Apply a small amount of Ultra Shine from the Scratch-B-Gone kit onto the appropriate abrasive pad. Or use an automotive rubbing compound on the sandpaper.
Begin rubbing the damaged area of the satin in the direction of the grain covering over about a 5-inch area at a time. Slide the pad backward and forward increasing pressure as needed until you see the scratch is disappearing.
Repeat this process until the scratch is removed and the surface is restored. For a deeper scratch, dry rub the area with the coarse pad, and wipe area off with a microfiber cloth to make sure the scratch is gone.
Blend the metal surfaces by using the finest grade sandpaper or abrasive pad with the rubbing compound or Ultra Shine and gradually increase the area around the original damage to about three times the original scratched area. Be sure to go with the existing grain of the material so you don't create crosshatching.
Posted on Sep 30, 2010
  • 1218 Answers
SOURCE: I have a Kenmore Elite Model 106.57863801 side by
Good day,
Spraying a good lubricant on the hinge pins should solve your problem. Sprays like WD-40 shouldn't be used because they may come in contact with your food.
I suggest you call around to your local appliance parts houses to see which one's carry a "food compatable" spray.
It's safe to use around food and can be saved for future use. Most service techs I know carry it with them in the service truck to use when needed.
Posted on Oct 05, 2010
Tip
How to clean stainless steel appliances
Use extra virgin olive oil to clean and shine stainless steel. Apply with lint free cloth and rub into stainless steel following the grain of the steel. Then with dry portion of cloth buff like you would car polish and you will be amazed at the shine. It also provides some protection due to the fact it is a oil.
on Feb 02, 2015 | Kitchen Appliances - Others
How do I clean, what appears to be, rust marks on my stainless steel refrigerator
DO NOT use anything but a dedicated stainless steel cleaner. Some types of Windex have ammonia as one of the ingredients and you can imagine what that will do to your stainless steel finish.
Mar 23, 2014 | Samsung RFG297HDRS Stainless Steel
How do I clean my stainless steel surface on my Samsung Refrigerator. I have use several stainless steel cleaners and they all leave a film. I am unable to get out drip stains from water.
Start with soap and water to remove old polish, then use CLR to remove build up, then use a product called Stainless steel Magic to clean. Make sure when your done to buff off all remaining cleaner
Jun 14, 2012 | Samsung RF265AA Bottom Freezer French Door...
How can we clean the baked on food from the oven racks and rack holders? Stainless steel cleaner does not touch it.
To clean the stainless steel without marking it you can first try non-caustic oven cleaner, if you use normal oven cleaner the acid in the cleaner will etch "eat" the surface of the stainless steel
May 05, 2011 | Electrolux 30" Built-In Single Electric...
How to clean maytag stainless steel finish on appliances
HOW TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do not use abrasive or harsh cleaners such as window sprays, scouring cleansers, flammable fluids, cleaning waxes, concentrated detergents, bleaches or cleansers containing petroleum products on plastic parts, interior and door liners, or gaskets. Do not use paper towels, scouring pads, or other harsh cleaning tools.
How do I clean and care my stainless steel surfaces such as refrigerator or any other stainless steel made appliance?
NOTE: Just because a cleaner is a liquid does not mean that it is nonabrasive. Many liquid cleaners designed to be gentle on tile and smooth surfaces still damage stainless steel.
> Avoid Citric acid
-it can discolors stainless steel. To avoid damage to the finish of your stainless steel appliance, do not allow these substances to remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If you want to clean safe and keep the sparkling steel you can purchase STAINLESS STEEL WIPES this wipes is ideal for cleaning food spills,grime and stains leaving surfaces shining like new. This wipes is for stainless parts only make it sure this stainless steel wipes to come into contact with any plastic parts.BUT THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH CLEAN WHITE CLOTH.
Jan 26, 2011 | Maytag Refrigerators
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Streaky stainless appliances.
Hellocmmirabile,
Welcome to Fixya,
You asked, What do you use to clean stainless appliances so they won't streak?
At this site of our sponsor, they have a good stainless steel cleaner.
http://www.pcappliancerepair.com/cleaners.shtml#cleaners
Stainless Steel Cleaner - 10 oz
P/N: 31462 Stainless Steel cleaner made by Whirlpool. Cleans and polishes stainless steel. Non abrasive and residue free. 10 oz bottle
Availability:
In-Stock $ 6.99
I use a $1.00 bottle of alcohol from the dollar store,
which is already mixed with water 80-20% OR or 50-50 %.
What ever they have available and I do it twice.
Let me know how you do.
Thank You for using our site.
Huuum,
Please remember to leave a solved rating at fixya
Oct 21, 2008 | Stainless Refrigerators
Refrigerators Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
