Question about Xitel INport Deluxe
Inport 0047d385 In setting equipment up, the info about Win 7 setup is sketchy at best. Having followed the directions as well as can be, I get: LP Recorder has terminated. No device driver present Adding recording buffers (0047D385) Looks to me **** Microsoft provided drivers.............. Any ideas: gtennant
5 Suggested Answers
SOURCE: Xitel INport audio not coming through
Change your recording device in your control panel back to your soundcard that will allow the sound back to your computer. In order to record you had to change it to Inport.
Posted on Apr 23, 2008
SOURCE: Message given that device is unknown. Not able to
thats is solution,
Posted on Jul 13, 2009
  • 3278 Answers
SOURCE: I plug in my Inport
Hello.
There may be a conflict with your sound card.
From Xitel:
1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback.
Hope this helps.
Posted on Aug 22, 2011
  • 9 Answers
SOURCE: xitel INport requires a password.
The password is printed on the sleeve of the CD that Xitel supplied with the INport.
Posted on Feb 15, 2015
After Windows 10 update, why doesn't my computer communicate with the printer?
Suzanne, you may have to reinstall and set up the printer, again. The best place is the website of the printer manufacturer. Look for downloads, updates, or such words. This should not cost any money. Follow exactly the install directions. If still an issue remains, seek support from the techies at the printer manufacturer site, likely everyone is having the issue, and they would want to fix the issue.
Jan 22, 2016 | Office Equipment & Supplies
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
0047BB69 with the LP Recorder
Windows 8 is not compatible with the Xitel versions of LP Recorder. Xitel customers are eligible for a discounted upgrade to the latest CFB Software version of LP Recorder:
http://www.cfbsoftware.com/shared/upgrade.aspx
Nov 06, 2013 | Xitel INport (HFLI1X1) Audio Input
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
I need a software for windows 7 for xitel inport
INport - Windows 7 compatibility
Your INport Deluxe hardware and software is all Windows 7 compatible straight out of the box. Please click below to download the Windows 7 user manual addendum for instructions on how to install your INport Deluxe hardware.
http://www.xitel.com/USA/support_inport_vista.htm
Apr 08, 2011 | Xitel INport (HFLI1X1) Audio Input
Can't seem to install my xitell inport, can you help?
Xitel customers using the LP Recorder and LP Ripper software supplied with their INport are eligible for free technical support from us, CFB Software:
http://www.cfbsoftware.com/shared/support.aspx
Regards,
Chris Burrows
CFB Software
Sep 02, 2010 | Xitel INport Deluxe for PC
WPSM54G linksys printer server software does not install on windows 7. Need a driver.
win 7 has some problems with networking equipment. there is a method for installing the wpsm54 on vista and win 7. go to this link it has a good clear set of directions. good luck, aokcomputer
http://www.ehow.com/how_5396340_set-vista-vista-windows-linux.html
Jul 23, 2010 | Linksys WPSM54G Print Server
I am having a sony company laptop and i want to get the drivers which will support window7 as it is a old model laptop and now is running on windowxp
You will save yourself a lot of headaches if you don't go to Win 7.. Win 7 is brain dead with older equipment, my advice is to NOT upgrade old equipment.. It will offer NO improvement over XP, in fact it probably will be worse.. Win 7 is ONLY OK, on MODERN 1009 - 2010 equipment, anything outside that.. is just a problem waiting to happen, Drivers are a nightmare, even if you can get them.. Please do yourself a favor and stick with XP. OR get a NEW machine that will work with it.
Feb 28, 2010 | Computers & Internet
I lost the cd with the drivers for an Acer ZG5 AOA110 with Windows XP Home Edition, I downloaded them from the Acer's website and now I don't know how to install them because they are zipped and I want to...
This procedure involves you having access to another pc. If so, it should get you on the right direction. Make a folder and unzip the drivers into this folder. Borrow any win xp cd that you can obtain. Download a program from the internet called nlite. A google search will take you there. Install this program. With nlite you can create a bootable cd/dvd disc to replace your lost one. The program
will take the win xp setup files from your borrowed disc and integrate the drivers into the setup directory. You can even intregrate service packs into the setup. In the unattended settings you can insert the license key and all the user info.(ie: country, date, timezone, etc.) Nlite has a wizard so
even a novice pc user can follow thru with the creation. This disc will become your new one.
Finally check the following url to ensure you have the correct drivers downloaded.
http://www.acerpanam.com/flex/acer/bin/acer.htm#
Nov 07, 2008 | Acer Computers & Internet
Xitel INport Deluxe Logo
103 people viewed this question
Top Xitel Computers & Internet Experts
KG John Justin
KG John Justin
 Grubhead
Grubhead
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
