Question about Belling XOU252 Electric Single Oven
LED display stopped working
The led display on the front of the cooker has stopped working. Everything else is fine. I'm guessing a fuse might have gone or the bulb itself - but I cannot see how to access the LED panel. Can you help?
Thanks
  • 163 Answers
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Posted on Jan 04, 2009
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Nothing is working in my oven not even the led timer is lighting up
When the timer, clock etc didn't light up my oven stopped working. Replaced the clock display unit and all is now fine. A simple switch over just remove one wire at a time and place it on the new unit, the only difficult part was gaining access to remove the display unit itself.
Sep 08, 2015 | Ovens
Led display not working
I would imagine that the cooker has an internal battery that powers the clock when the oven is not on mains power - since these are so old now, the battery, if THERE IS ONE NEEDS REPLACING.
Aug 19, 2014 | Belling XOU174 Electric Single Oven
STOP sign on cooker display
Try unplugging it for about a minute, then plug it back in. Not sure but that might solve the problem.
Dec 15, 2017 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
My LED display has disappeared on my Diplomat split level cooker, although my ignition is still working to light the oven and grille. Any solutions to this problem please?
ISOLATE MAINS POWER BEFORE REMOVING
The LED display uses low voltage input, often a connection problem causes the display to stop working, check wiring carefuly, as small light connectors is used. If all wiring connections look and feel secure, you have to dig deeper, a multimeter would be handy, to measure input voltage, but a level of understanding electrics or even better electronics would be required. If unsuccessful referr to whitegoods.co.uk for a replacement you will need the model and serial numbers to check for the correct part.
Hope this has been helpful.
johnf1
May 17, 2011 | Ovens
I have a diplomat fan oven. I repalced the fan element about six months ago. everything worked fine, however in the past couple of weeks the motor has been running slowly and erratically. now something has...
Sounds like the fan motor has failed altogether, and as a result the oven element has probably blown again due to overheating of the element.A ew fan and element is more than likely going to be needed to correct the problem.
Dec 16, 2010 | Ovens
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
Belling XOU252 Electric Single Oven Logo
262 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
