Question about Garden
LA105 mower won't move when put into gear
Had same problem last week but it eventually kicked into gear. This week it moves very very slow, it moves a little then stops then moves a little more then stops and so on . I changed fuel and fuel filter and air filter and it still the same.
    Novelist:
    Scholar:
  • 80 Answers
Is this happening in all gears or just one? Is the motor bogging at all. If not chances are the problem is in the drive belt to the transmission or in the transmission itself. Check to make sure you are getting it into gear. you should be able to feel the transmission hit a notch for each gear. If you can't, chances are the little module in the top of the trans that sets the gears has broken and needs to be replaced. Often these get sticky before going bad. If the motor is running normally though, it's not the engine, it's drive belt or transmission. with the mower off, you can check the drive belt tension by simply having the clutch pedal in the out (drive) position. In that position the drive belt should be tight enough that you really can't slide it in either direction without causing motion on the motor pulley. If it has slack in it, then your clutch is probably out of adjustment or your drive belt has stretched beyond it's working life. Have you smelled burning rubber at all.. if so the belt is probably slipping. If not, it's more likely that it's in the transmission.
Posted on Nov 14, 2013
  • 32 Answers
SOURCE: I have a 20hp turbo twin cylinder, 42
I think that it is not imposible to switch gears it is just very hard. i had that problem once too!
Posted on Jun 21, 2009
  • 41 Answers
SOURCE: mower will not move while in gear
check to see if there is a second belt for the transmission, you may have nicked that belt or put the pulley tession to the wrong bulley.
Posted on Jul 15, 2009
mowerman1857
  • 389 Answers
SOURCE: lawn mower will start, but won't move????
If you have had either of the rear wheels off, remove the cover from the center and observe the shaft with the engine running and transmission in gear. If the shaft is turning, you have lost the 1/4 inch key that locks the axle to the wheel to make it go
Posted on Sep 15, 2009
Testimonial: "thanx...i will try this "
nova2nv
  • 197 Answers
SOURCE: John Deer Riding Mower L100 gears will not engage.
Check input drive pulley on top of trans to see if splines are worn out.Does the pulley turn?If so see if the shaft turns as well.
Posted on Nov 13, 2009
juliefarley
  • 17 Answers
SOURCE: 24 hp LA165 mower. While mowing
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Posted on Jul 18, 2011
My stick Audi A6 Quatro had some gear slip when I shifted, then a lot of gear slip, and now the car doesn't move. I can shift into any gear without using the clutch. The RPMs go up, but car does
Your friction plate is kaput. Replace clutch system. Sounds like the pressure plate needs attention as well. No idea of price but get prices of "clutch kit" on the web and you can have an idea.
Oct 08, 2012 | Audi A6 Cars & Trucks
Clicking from front passanger side wheel
continuous velocity joint going bad (CV JOINT). will need to be replaced, may go out at anytime, or may last a good while. likely reason is boot was cracked and grease was lost, so over time the joint gets heat cracked, and eventually breaks and bearings come loose leaving veh imobile (won't effect engine, wheels just won't move)
Aug 27, 2012 | Cars & Trucks
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
