Question about Jenn-Air Refrigerators
Jen air jcb2388gt compressor won't run
Fan runs replaced overload relay
the dr
  • 447 Answers
SOURCE: low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Posted on Oct 11, 2007
  • 37 Answers
SOURCE: FRT18L4FW3 Frigidaire Compressor Kicking Off Prematurely
Sounds like it is either low on gas or it is tripping the internal overload which would mean you need a new comp. Check on warranty
Posted on Jan 03, 2009
  • 1169 Answers
SOURCE: compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
Posted on May 10, 2009
  • 3368 Answers
SOURCE: compressor doesn't run but fan does
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Just a guess but it could be either the start relay or a start capacitor if there is one. If not it may be a bad compressor winding. With the unit unplugged measure the resistance between the pins and the compressor case. If it is not infinite the compressor probably has a shorted winding and would need to be replaced. Be sure all wires are off all the pins before taking resistance measurements.
Good Luck,
Gilshl
Posted on Nov 29, 2009
  • 2468 Answers
SOURCE: compressor kicks off on overload/relay. Even after
are you sure the condenser fan is running correctly to move air over the condenser and is the condenser free of dust and dirt so it can cool properly from air movement from the fan
Posted on Mar 23, 2010
When the compressor tries to come on, why does it click and hum, then clicks off?
Two causes for that situation. The compressor has a start relay and a overload mounted on the 3 prongs. When the relay/overload is bad, compressor will kick on, hum, then a click sound. The click is the overload. Or, the compressor is drawing too much power and the compressor is bad. 90% of time it's the relay/overload but you need to check and make sure fan is running by compressor and coils underneath are not clogged up. Poor air flow around compressor can cause overload to go bad.
Aug 19, 2015 | Refrigerators
Refrigerator compressor won't run
Plug it in. It may be in Defrost cycle, nothing runs when in defrost cycle. Amana's are famous for defrost terminators to go bad. The fan in the back should be running even if the compressor is bad. Do you hear a clicking in the compressor? If so the overload in the compressor is bad.
Jul 28, 2013 | Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
After moving our fridge, it will not cool. Fan is turning but compressor does not seem to be running.
You need to check the overload relay, there is a plastic box on the side of the compressor with several wiring going into it. The overload relay fails often causing the compressor to try to restart every 3-5 minutes. If you remove this box on the side of the compressor and shake it, if it will rattle it's bad and needs to be replaced. Otherwise you just have a bad compressor, but most of the time it's the overload relay.
If after replacing the overload relay and you still have the same issue, that means your compressor itself will need to be ordered and replaced.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Refrigerators
10 year old maytag MTB2154DR compressor won't start fans runs. How do I replace the start relay? Can I put a 3 in 1 hard start kit? thanks Bob
Hello Bob,
To replace the replay just remove the old relay and install the new on and connect wire(s) to new one exactly as they were connected to old one, it is recommended that the overload also be replaced,but not necessary to see if the compressor will start. I begrudgingly say yes a 3n1 could be used and some will say thats fine but in my experience if a 3n1 is needed the compressor is on its last leg and adding a huge capicator onto something that never had it will send a dying compressor over the wall so quick, and money is wasted on the 3n1 and the end result is a dead compressor.
If you have a meter the relay and overload can be checked first, by checking for continuty on the relay by placing the meter leads into the 2 holes on the compressor where they fit onto the pins of the compressor and check for ZERO ohms resistiance and also zero ohms on the overload by a meter lead in where it fits on pin on compressor and on wire terminal where wire connects. Both relay and over load should have zero ohmsresistiance and continuty if good.
the part number for the OEM relay is 10097204 it should be in stock at your local appliance parts store.
Gene
Aug 17, 2011 | Maytag Refrigerators
Previously running fine, after power washing, my Whirlpool model EET-171 PK refrigerator won't start. The compressor turns 'on' for a couple seconds, then I hear a click from the relay at the...
I would try replacing relay and overload that plugs into compressor. Hopefully compressor hasn't shorted out. Take your model # to your local appliance parts store and tell them what you need.
Nov 02, 2017 | Refrigerators
. kenmore side by side blows warm air, after
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 30, 2011 | Kenmore Side by Side Refrigerator
Compressor kicks off on overload/relay. Even after replaceing overload/relay and cap. It will run ok for a week if you let it cool down.
This is often found in small compressors when they heat up too much or too often. check to be sure the condenser coil is clear and has good airflow. If so and it still trips on overload then the compressor is bad. Hope this helps. Good luck.
Mar 23, 2010 | Amana ARB8057CSR Bottom Freezer...
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
The starter/overload and overload protector unit melted but the capacitor looks ok. Does this mean the compressor is shot or just got overloaded?
The easiest way to find this out , is to check the condenser. Make sure that the condenser is not clogged up with dust and that the condenser fan is working. Replace the start relay. Turn it back on. If it starts right up then it probably overheated and melted the relay due to the condenser fan not working or the condenser clogged with dust. Air circulation through the condenser and air being circulated over the compressor in how it cools itself. If the compressor will not start or if it runs for a little while and then shuts off from overheating, then you have a bad compressor.
Nov 12, 2008 | Refrigerators
Refrigerators Logo
23 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
