Question about Argosy HV335T
What is the remote HV335t code that is duplicate of a Toshiba DVD player. Need model number of Toshiba.
I have been told that the HV335t uses the same code as a Toshiba DVD player. Anyone know the model number?
How do I unlock region codes on a Toshiba SE-R0220 DVD/VCR player? I've tried many codes for other toshiba DVD players but none of them work :(
The Toshiba SE-R0220 is the REMOTE model number not the DVD/VCR model number!
You need to find hacked firmware for the DVD/VCR model number you have that releases the region settings.
Write it to a CD RW or DVD RW disc and follow the instructions for updating the firmware.
There is a chance that the firmware will not update correctly and you'll be left with a DVD part of the system that doesn't work.
Nov 03, 2016 | Toshiba Televison & Video
Unlock region dvd code for toshiba model number sd1010kb
Hi this should work:
1) Turn on the dvd player
2) Press the eject/stop button on the dvd player (not the remote) to open the tray, and leave it open!
3) On the remote press 98790 (if done right, a message will appear stating that region has been changed to 0)
4) Done
Jun 29, 2012 | Toshiba Televison & Video
What is the uverse remote code for my toshiba sd-k760s dvd player?
Google the model number of the remote to locate and try all possible codes.
Some remotes have a search feature that allows you to try every possible code in sequence to see if any will work.
Apr 08, 2012 | Toshiba Televison & Video
Need code for Toshiba dvd player with Philips Universal remote
Hello
Code for Toshiba DVD with Philips Universal Remote control Model number 'SRU 5130' is [3021]
OK.
Apr 06, 2011 | Philips Televison & Video
I upgraded my argosy hv335t firmware to 2.3 then rolled back to 2.1c (all upgrades done from a usb device which was safely removed from pc) after the player did the upgrade it restarted then got stuck on...
go to this site: http://www.argosyusa.com/download.asp?DefaultTab=0
there are two different verrsion of the HV335T one with "VR" after the barcode and the other with no "VR" after the barcode you will see what version is the one you need
for no "VR" code are this firmwares D2.35 (beta) V2.3 V2.1c V2.0 V1.01 (original in the player)
for "VR" code are this firmwares B1.35 Same as D2.35 for HV335T VR R1.1 Same as V2.1c for HV335T VR so, download the one you player needs and do the upgrade
Leo
Feb 12, 2011 | Argosy HV335T
I need remote control codes for toshiba sd-k620
Checkout http://manualfox.com/remote.htm - just send them the model numbers of remote and player and they will come back with a solution.
Jul 23, 2009 | Televison & Video
Toshiba Tv remote control
I NEED THE CODEOR CODES THAT TOSHIBA DVD-HD A30KU TU USE AND RECCEIVER ONKOY
Jun 09, 2008 | Toshiba HD-A30 HD-DVD Player
Argosy HV335T Logo
95 people viewed this question
Top Argosy Televison & Video Experts
Are you an Argosy Televison and Video Expert? Answer questions, earn points and help others
