Question about Microwave Ovens
Panasonic Inverter Genius Sensor 1250W reads code H97
Does not turn on reads code H97
  • Anonymous Mar 15, 2014
  • Microwave Ovens Master
  • 9,047 Answers
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Nov 03, 2012
3 Suggested Answers
SOURCE: panasonic inverter genius sensor 1250w, turns on
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Posted on Mar 01, 2011
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Posted on Apr 24, 2010
Trouble code H98
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
Panasonic inverter 900w microwave fault code h97
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
Feb 09, 2010 | Panasonic Microwave Ovens
Panasonic microwave Genius Sensor 1250 W
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Microwave Ovens
Microwave Ovens Logo
588 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
