Question about Killer Tools Door Skin Remover with Pneumatic Door Skin Too
Adjust carbs on 2006 gtx 800 ho
Any tips on how to go about this procedure.... everything looks real jammed in there and the air box clamps, you can only access one.
    Problem Solver:
  • 11 Answers
If you have not been there, www.dootalk.com has a wealth of information for your sled, and lots of friendly people. They do pack the new sleds tight. Get the longest most comfortable Phillips screwdriver you can find. It will be your new best friend. About 15" long should do. Then you can reach deep in there to the second carb.
I would give you specifics but i am more versed on the ZX and XP as opposed to the REV.
good luck!
Posted on May 20, 2009
How do I set the float and fuel mixture screw on a 1984 225dx 3wheeler
Help with yamaha 225dx carb? or?? - 3WHeeLeR WoRLD
www.3wheelerworld.com > Forum > The Goods > Trikesylvania
Dec 21, 2002 - 15 posts - ‎8 authors I did ride a polaris 400 4x4 once but thats about it, I bought a 225dx ... i took of the carb, and the fuel pipe and the air one were clocked up, ... a lean mixture with what little gas was left in the carb and then finally ... adjustable screws etc. clean them withgas, CRC and compressed air. ... 1984 yamaha 225DX Thread: 185s troubleshoot cold start please
Apr 4, 2013
Thread: 85 YTM Tri-moto 200 wont start....need help
Jun 3, 2009
Thread: carb rebuild on 85 yamaha 225dx
Sep 13, 2006
Carb Adjustments on 225dx
Apr 18, 2006
More results from www.3wheelerworld.com
3WHeeLeR WoRLD - Carb Jetting 101: Terms, Tips and ...
Nov 28, 2015 | Motorcycles
Craftsman schematic
Most are pretty simple the carb linkage should have a small moon shaped disc with three or four small adjustment holes for the bent tip of the throttle cable. After attaching the cable to the handle and snaking it to the carb. There is a small clamp that will hold the cable in the adjusted position .slide the end under the clamp and then connect to one of the holes on the linkage..slightly tighten the clamp and slowly move the handle unti the handle goes the full travel..then check to see it the carb linkage goes to full throttle and backs off to idle..if it does not..loosen the clamp and keep adjusting to get the desired full throttle and idle..May have to play with it a couple of times but it will adjust..good luck..
Jul 23, 2014 | Craftsman Garden
Cleaned carbs on 1989 Radian 600, now idles at 6-8K RPM. Please help.
Please check the following:
- Throttle control cable adjustment.
- Foreign matter in throttle plate.
- Fuel line clogged.
- Water contamination in fuel.
- Vacuum leaks in the intake manifold or at the carburetor.
- Carburetor base gasket or seal.
- Air/ fuel mixture adjustment.
- PCV valve.
- Valve clearance.
May 08, 2014 | 1989 Yamaha YX 600 Radian
I need to remove the carbs from a 1987 Kawasaki GPX 750R. Any tips or suggestions? There is very limited room due to the air box (which can't come out until the carbs are off. There must be someone out...
remove seat and side panels to gain access to everything. unbolt the airbox there should be three or four bolts and atleast one is going to be hidden. loosen clamps on air boots from airbox to carbs and slide back air box. it might only move an inch or two but that is all you need. unhook everthing on carbs and loosen clamps on intake boots. slide and wiggle back on carbs and you should have enough room.
Oct 02, 2013 | kawasaki GPX 750 R Motorcycles
Service manual for a 2006 500 Polaris Sportsman HO
I have a 2006 Sportstman 500HO ATV, EFI. Sometimes it will run 100% correct, other times it will start, idle fine but then when giving it throttle will will start to surge almost like it's hitting a rev limited. Sometimes it will backfire and stall. I already replaced fuel filter, flushed the fuel lines and gave it fresh gas and installed a new spark plug, but no good. I also checked the throttle switch and it's not making contact to stall it. I download the service manaul and tested each sensor and they tested fine which is probablt why I get no check engine light.
This ATV is mainly used to plow snow in my driveway, no salt. It's used around my property but very lightly. It's still as clean as it was when I bought it and it doesn't have but about 40 hours on it.
Polaris 500 HO EFI 4x4 ATV: Vin# 4XAMH50A56B707664 purchased 6-8-2006
gtopercy@comcast.net
May 20, 2010 | Polaris ATV
I have a 2006 Kawasaki Bayou 250 it is always fowling spark
does it backfire when revving down? are your spark plugs coming out black? if yes, you need to lean out your system a little by adjusting the mixture screw on the carb.
May 13, 2010 | Motorcycles
Cleaned the carbs, changed the plugs gapped at 34
I would be checking for air leaks, this will give you a lean mixture. In particular look for the seals for the balance tubes and each carb.
May 04, 2010 | 1998 Suzuki VZ 800 Marauder
Take the carb back off and adjust the float in bowl to spec.If you don't have spec just adjust till fuel stops overfowing an go with that.Yeah, it might take a few times.
Mar 21, 2010 | 2006 kawasaki KLX 250
My 2006 YAMAHA starts up...but when I rev the throttle it just dies. Whats up?
well how long has bike sat do u have to leave choke on if bike sat all winter and u cant take coke off carbs need cleaned if bike has not sat then look for vacum leaks by sprayin starting fluid around carb and air box if it revese high then u need to fix the air leaak problem by new boats or clamps
Mar 19, 2010 | 2004 Yamaha XVS 250 Dragstar
I have a 2000 ttr250. It sits a bit and ran real
The timing is not the problem. Air getting into the fuel mix AFTER the carburetor is the red pipe problem. Bad carb seals, loose clamps and fittings and old cracked hard rubber all can lean the mix and make the bike run hot. As to the carb, I would take it apart again and soak it for 30 minutes in denatured alcohol. Then use spray carb cleaner to finish up the cleaning. Be sure to spray into all carb circuits from both ends and pay special attention to the throttle and air screw holes. The setting for both screws is one and one half turns outward from a LIGHTLY seated position.
Feb 12, 2010 | 2002 Yamaha TT-R 250
Killer Tools  Door Skin Remover with Pneumatic Door Skin Too Logo
99 people viewed this question
Top Killer Tools Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Killer Tools Grinder Expert? Answer questions, earn points and help others
