Question about Whirlpool LER4634PQ Electric Dryer
Timer wont turn stays running - Whirlpool LER4634PQ Electric Dryer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the timer. Here is the part you need to order.
Posted on Nov 03, 2012
Why wont my kenmore elite sm9711034 wont cycle automatically?
This is almost always caused by a bad time. The solution is to replace the timer. What happens is the timer has a small motor on it that turns the timer, if the motor burns out or the timer gears wear the timer doesn't advance like it should.
Jul 01, 2014 | Kenmore 24032\24036 Top Load Washer
The LCD (24 hour timer) is blank so the heater wont work
There is nothing you can do, turn on your oven if electric, or if gas open a window 4 inches and dont sleep with a gas burner running.
Oct 25, 2012 | Dimplex OFC2000TI Heater
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
When i turn my dishwasher on it runs it wont change cycles and wont wash stays in the same cycle
This sounds like a bad timer.
It could also be a defective thermostat. This problem will become apparent with the water heat option selected. Check by running the dishwasher with this option de-selected and see if it proceeds normally through the cycle.
Hope this helps.
Sep 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Delonghi toaster oven wont turn off
have you cleaned the inside of the oven lately?  With the unit unplugged!
Mar 26, 2009 | DeLonghi DTT900 2-Slice Toaster
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Electric clothes dryer
The most likely cause is a bad timer. The timer determines how long the unit stays running (drying the clothes). A timer is typically $100-150.
Secondly, it could be a faulty motor. This part generally cost about $100-200 dollars.
Mar 21, 2008 | Dryers
Electric dryer wont heat or turn off
there could be a temperature switch that tripps off. look at the diagram and trace also the power to the timer motor. it seems that you lost your power to your timer motor that is why the timer stays @ what ever setting you set it.
Feb 11, 2008 | Kenmore 63942 Dryer
Whirlpool LER4634PQ Electric Dryer Logo
Dan Webster
Dan Webster
Sal DeAngelo
