Question about Dishwashers
My logik dishwasher ldw60s11 doesn't produce hot water on any cycle
megarza
  • 88 Answers
SOURCE: I have hot air but no hot water in my dishwasher
Check to make sure your supply lines aren't crossed and that your hot water supply is connected to the dishwasher
Posted on Aug 26, 2009
  • 901 Answers
SOURCE: All of a sudden the dishwasher water is not hot
Check the heater. Heater control circuit.
Posted on May 28, 2010
Macmarkus
  • 2605 Answers
SOURCE: My Asko dishwasher is not producing water
Hi, Welcome to FixYa. Based on your description that the dishwasher is indeed filling with water but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump. First though, do you hear a quiet sound ( it will be super quiet if the wash impeller is broke so you have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver ) of a motor once the unit has completed filling with water ? If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely. Let me know what you find and I'll try and help you move forward from there. Good luck, Macmarkus :)
Posted on Aug 02, 2010
Macmarkus
  • 2605 Answers
SOURCE: Re: Model # 665-17039401. Clean light
Hello, Welcome to FixYa.
Based on your description, "clean light stays on" this is actually an error code as you may or may not know associated with the heating process. What typically happens is poor water circulation preventing the water from heating properly.
To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Once these actions have been performed you'll need to clear the error code. to do so is as follows.
Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 10, 2011
Macmarkus
  • 2605 Answers
SOURCE: dishwasher soap dispenser doesn't open.
Hello, welcome to FixYa.
I understand you have a problem with a Bosch dishwasher as you described, "dispenser doesn't open. replaced with new one, ran a cycle and it still doesn't open".
I should be able to help, but I have a couple of questions. 1) What type of detergent do you use. 2) Does the machine complete it's cycle, or do you stop it manually. 3) Finally, have you tried a cycle without detergent in the dispenser to see if it opens ? When you reply I would like to verify the model so If you can provide the entire number, including the two digits after the forward slash, i.e. 06, 12 etc. It is on inside of door frame or tub frame around door opening as shown here for bosch.
...I'll see what I can find for you.
There are many possible scenarios even within the Bosch line so I'll need to clarify the entire model before moving forward.
Regards,
Macmarkus :)
Posted on Jun 24, 2011
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
Bf72 not doing the wash cycle correctly
If you are using hot water connection then check the temperature of incoming water is hot enough. If cold water inlet only is used then most likely the heater element or thermostat in the dishwasher is faulty and the water is not heating enough.
Nov 04, 2012 | Hotpoint 24 in. BF72 Built-in Dishwasher
Shortest cycle takes 3 hours
Maybe its build up inside the dishwasher. A solution to this is to run one of the avaliable products for cleaning out the lime/scale/crud inside. Just because it looks clean doesn't mean that the hidden pump and lines aren't either partially clogged.or almost blocked. Is the hot water at 140 degrees? If not then the element inside may be attempting to heat the water to that minimum setting, If this doesn't help then I'd look at replacing the timer.
Aug 29, 2012 | Whirlpool ADG75601 Builtin Dishwasher
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
Dishwasher runs, but the water doesn't seem to get hot and the dry cycle doesn't seem to be working. I ran a cycle with a bottle of dishwasher cleaner. It has little wax stopper that blocks the...
No there is not a reset button on diswashers. I would suggest you take the heating element out and check it with an ohmmeter to see if that is the problem - which is the most probable cause. If it is open - infinity reading on the ohmmeter, then it is bad.
If it is good then, it would be the control board.
Aug 14, 2011 | Dishwashers
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
113 people viewed this question
Top Dishwashers Experts
Owen Barnes
