Question about Blue Flame Heating & Cooling
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Units are approximately one year old. The pilots even have orange tips, but stay lighted just fine. There's an old CharmGlo nearby running off the same gas source and its flame is still deep blue. Suspected a line pressure drop, so I tied in a tank and regulator from six feet away to test and there was absolutely no change. Would now figure the air intake needs to be adjusted, but why the orange pilots and why the exact symptoms on two heaters?
  • Michael Andrews Nov 03, 2012
    Thanks. Already blew out the pilot and the burner openings, but now planning to disassemble and force air through the burner tube itself. Still puzzled that the pilot also has an orange hue.
  • Blue Flame Master
  • 3,313 Answers
Could be that the burner needs cleaning dirt in the burner tubes
Posted on Nov 03, 2012
  • 37 Answers
SOURCE: I have a Vulcan Freeloader that is over 10 years
The pilot assembly is stopped up. It will need to be taken apart, blown out or cleaned and re-intalled. The yellow, lazy flame is preventing the thermocouple from getting warm enough to allow the main burner to ignite. Hope this helps.
Posted on Jan 20, 2011
Buffalo12980
  • 625 Answers
SOURCE: Pilot light seems to high
there may be an adjustment screw for pilot height. you'll have to look at the valve. a pilot should have an inner cone of greenish blue color and the surrounding flame should be a deep blue no yellow or orange tips. the pilot burns pure fuel no air. the main valve does mix air with the gas in order to burn.
Posted on Nov 04, 2007
  • 41 Answers
SOURCE: yellow pilot on heater
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
SOURCE: blue flame heater pilot wont stay lit
the thermocouple is bad.replace it and your good to go.about 8 or 10 bucks at your local hardware
Posted on Feb 03, 2009
  • 77 Answers
SOURCE: dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Posted on Jan 22, 2010
Orange pilot flame
Orange or yellow gas flame indicates air is not being mixed with the gas before burning.
The pilot burner has air holes to allow air to mix with the gas for efficient blue flame burning.
The air holes are probably blocked if the flame is approximately the usual length or longer. If it is significantly shorter it indicates the gas pressure to the jet is reduced.
Feb 07, 2018 | Heating & Cooling
I have a 40 year or so propane heater manufactured by King Stove an Rane. It has a couple things adjusted on it, so I am looking for an owner/repair manual for that brand.It is 65,000 BTU if anyone knows...
I think you'll find that a hard copy of a manual for an obscure brand that old will be impossible to find.....However.....the GOOD thing is units that old are very simple to troubleshoot and repair.
If there are no obvious external damages, and it is set up for the gas you are using, i.e. natural gas or propane.... turn on the gas and leak test the connections. If good, twist the control knob to the pilot position and light the pilot light. If it holds in after 45 seconds, good, turn the gas knob to the on position and adjust the thermostat to a setting above room temperature and observe operation. If the pilot goes out, replace the thermocouple. Around 40 years ago most small units still utilized thermocouples and not electronic ignition.
The flames should have two blue cones...an inner darker cone enclosed in a larger, softer outer lighter blue cone with an occasional flicker of orange on a few of the flame tips. NO YELLOW !!!! If its on natural gas, there will be air shutters secured by a captive screw on the venturi end of the ribbon burners. Air mixture can be adjusted here to attain the aforementioned dual blue cone flames. If it is on propane, those shutters will either by removed or need to be in the 100% open position.
You really didn't describe a problem, so this should be enough to get you started.....remember if you do not feel comfortable messing with gas or electric and are unsure of your level of expertise, or of your mechanical ability it is best to leave gas and electric problems with a gas fired appliance to a professional service man.
Jan 05, 2015 | Heating & Cooling
I have a Vulcan Freeloader that is over 10 years old. The pilot does not stay lit when I release the red button. Also, the pilot flame is orange. What can be done as the main burner would not work when the...
Jan 20, 2011 | Heating & Cooling
Glo warm ventless heater will not stay lit more than a few seconds burner not pilot lite
this happens yearly..usually it is the thermos couple needs cleaning..this year the pilot orfice itself was dirty and throwing a weak orange flame that was not even touching the thermo couple..I just gave the orfice a good cleaning and now the flame reached out as a long BLUE flame touching the thermo couple and it stayed lit on the first try
Dec 02, 2010 | Desa International Blower Glow Warm Wall...
I turned my propane fireplace on and it set my smoke alarm off. We have lived here for three years and never had this problem before. Please advise.
check to see if the flame is pure blue. if not you have incomplete combustion letting CO or CO2 into the room. The flame will look yellow if this is the case. An orange flame indicates dust and dirt around the burner assembly. If it is yellow, the should be 1-2 set screws on the back of the burner assembly that will let you adjust the primary air being mixed with the propane.Adjust until you get blue flame and tighten set screws.
Dec 05, 2009 | Vanguard International Blue Flame - Large...
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Oct 24, 2007 | Procom ML300EBC Heater
Heating & Cooling Logo
423 people viewed this question
Top Blue Flame Heating & Cooling Experts
Paul Carew
Are you a Blue Flame Heating and Cooling Expert? Answer questions, earn points and help others
