Question about Philips SHL9600 Headphones
Philips SHL9600 broken cable
Are spare cable available?
The driving belt of my Philips HTS3500S is broken. How can I get hold of spare parts?
Take the original one into a shop that sells spares for washing machines or vacuum cleaners and just match the length and width to the ones they have available. It is just a reinforced rubber band- you just need to get one that fits. Washing Machines and Vacuum cleaners use belts as well and these tend to be stronger so they last longer.
Jul 13, 2011 | Philips HTS3500S System
No sound coming from left ear initially, now no sound at all.
Sorry, it's probably not fixable. The wires are either broken internally or have become detached from the solder fixings and the headphones are not designed to be repaired, nor are spare parts available.
The only exception is if the plug on the end is broken or has broken wires. Wiggle the wire at the plug end only whilst wearing the cans. If you get sound, then identify where the wire has broken and cut the plug off at that point. Strip the wires, correctly identify the left and right conductors and fit a replacement plug using soldered connections. Ensure that the screening sheath is correctly soldered to the casing (it's the earth connection for both conductors) and close the new plug casing.
In practice, it's fiddly, and only to be done if you're confident with a soldering iron. If not, just do as Philips intended and bin your old cans and buy new: it's not as if the SBCHP430/00 was an expensive model to start with.
Feb 16, 2011 | Philips SBCHP43000 Headphones
Hi my tv makes a chirping sound? it a philips 60pp9202 any ideas?
Bad High Voltage Generator. Part is No Longer Available. I need one myself. I saved the chassis for spare parts.
Dec 10, 2010 | Philips 60PP9202 60" Rear Projection...
The cord on my philips shl9600 headphone was recently severed. The cut happened just below the volume control dial. Are these headphones now completely useless, or can the perfect working head set still be...
See my tip on replacing dodgy cables plugs on headphones. Just click my name. I doubt you will be able to save the volume control, unless it has screws to open it.
Nov 21, 2010 | Philips (33-01-031) Headphones
My JVC everio GZ-MS120SAA is broken. When i open the screen the camera does not turn on but when its half open it works can u please help me ???? thank you
Problem is with the ribbon cable interconnect between camera and screen. Available as spare, but very tricky to replace. Probably a camera shop is your best bet.
Sep 02, 2010 | JVC Everio Digital Camcorder
2003 chevy surb... can not release my spare tire...cable is broken ,,,nothing to pull on help !
If when you turn the crank nothing happens to drop the tire. Look up inside and see if the cable is loose (most likely not) if not the assembly is broken, you will have to cut the plate that holds tire up and replace the spare tire cable and crank assembly.
Oct 08, 2009 | 2003 Chevrolet Suburban 1500
Broken lcd screen - PET704
You will find it is better to buy a new player. The cost of the part and repair will be about the same or more. You can still use the player with the a/v output to another monitor or television. Just use the supplied cables or purchase some for the connections. I hope this information helps you with your problem.
Apr 23, 2009 | Philips PET710 Portable DVD Player
Broken plastic slides power window
If you go to the VW dealer they make a left and right repair kit for the windows. the kit will come with updated new sliders and cable
reference part # 1CM-898-655-A for the left door
Right door part # 1CM-898-656-A
Jul 13, 2008 | 2001 Volkswagen Beetle
Philips SHL9600 Headphones Logo
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
