Question about Kenmore Dryers
When do I need to relace my dryer belt - Kenmore Dryers
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 03, 2012
All power is good, heats up but drum won't turn. Hear humming noise after pushing start button. Relaced motor,thermal fuse and thermistor. Still nothing. Checked door switch. Any other suggestions?
Betty,
When you replaced the motor, did you also replace the belt? If you had not said that you already replaced the motor, I would have suggested that the belt was broken.
Jun 09, 2015 | Kenmore Dryers
My Maytag dryer will not not turn the drum. The red light (more or less dry time sensor light) come on. I relaced the door switch. I do not get a beep. What else could be wrong? MDE6000AYW
Hi godinae...
If you hear you motor running then it sounds like you have a broken drum belt...you will need to replace it or have it replaced.
If you do not hear the motor running then it could be the motor or control panel if you have one.
Free answer Please take time to rate me
Jun 05, 2011 | Maytag MDE6000 Dryer
How do I replace the dryer belt on a kenmore 70 series dryer
remove two phillips screws under lint screen trap door pop lid up... remove two corner screws usualy 5/16 nut driver lift upward and off to the right idler pulley bottom left pat attention to belt routing before taken off relace pulley change belt and repeat steps and reinstall
Jan 31, 2011 | Kenmore Dryers
One of the belts have gone and need to know how to relace it
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch.
Remove the lint filter, and the two screws that hold the lint filter housing to
the top of the lid.
Then remove the top of the dryer.Most lids clip on to the base of the machine,
some slide off.
Remove the front of the machine, this will expose the belt and drum, remove
the drum and belt and this will expose the drum rollers, idler arm bracket
with pulley, and motor with pulley.
Pay attention to the route of the belt,this will come in handy when you go
to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum
not to turn.
While you have the drum out, I would recommend that you lubricate the drum
rollers at the shaft of the roller with a good grade of machine oil like 3
in One oil. This will save you a problem later with the rollers getting
noisy, also check your drum rollers for flat spots, if they have flat spots
on them this will cause a noise like a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Free answer...Please rate me
Dec 22, 2010 | Dryers
IT WILL NOT START UP.. IS THERE A FUSE I CANN RELACE?
Hi,,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 28, 2010 | KitchenAid Dryers
How do you relace the spring in a hotpoint v3D01 dryer?
have just bought a new doorhandle on a hotpoint freestanding dryer v3d01 can anyone help us out in how to fix it plz.. thankyou shirl
May 18, 2010 | Dryers
KENMORE SERIES 80 DRYER..The Tensioner use it or not and how?
To fit the new belt, you will need the idler pulley (tensioner)...
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, pull it around the motor pulley (this should force the idler pulley to "open up" and add tension).
If you still need help, I will try to provide you with a diagram shortly.
Mar 02, 2009 | Kenmore 62622 Electric Dryer
Dryer belt broke on my kenmore series 80
With the front cabinet panel off, place the drum against the back and on the rear rollers. The roller on the right will sometimes move toward the rear so reach from underneath and pull it forward. The rollers should sit in the groove. The drum will tilt forward but shouldn't fall off. Route the belt around drum, pulley and motor. Tilt the drum back and support it while placing the front panel back onto it's hooks. With the front panel on (don't screw it on yet), rotate the drum by hand to make sure the seal is not kinked and the belt won't slide off the pulley or motor. If all is well screw in the front panel and re-assemble the rest.
Feb 16, 2009 | Kenmore 62622 Electric Dryer
A/c belt relacement
DO this with a COLD engine, so you do not burned by a hot engine...Loosen the 14 millimeter nut on the idler/tensioner pulleythat the AC belt rides on. Do NOT remove the nut, or the pulley will fall off. Then loosen the long 12 millimeter bolt, which will remove tension, and will let the pulley extend. Remove the old belt. Spin the tensioner pulley with your hand, make sure that it spins free & is not noisy, Fit the new belt, and tighten the 12 millimeter bolt until the pulley retracts,and tightens the belt. Finally, retighten the 14 millimeter nut.
Dec 31, 2008 | 1995 Toyota 4Runner
Dryer wont start up quickly
HI the belt is worn and so it slips on the motor pullet. relace the belt thanks the appliance docp
Oct 15, 2008 | Amana Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
