Question about Aiwa NSX-DS55 CD Shelf System
Rear Speaker problems
I love this system. It is inexpensive and puts out some good sound. I've already taken it in to replace the fan in the player though, and now the rear speakers are wierd. When the rear speakers are chosen in the surround settings, they buzz. It isn't the speakers because I switched out the center speaker with one of the rear speakers, and the center speaker made the same buzz noise. It also doesn't matter what level the volume is, it makes the same buzz regardless. Music still comes out of it, but it is slightly delayed and sounds echo-ish. I think this means it is an output problem. Do I need to take it in to get it repaired? Thanks for any help or ideas!!!
How to hookup rear speakers/would like to see pitcher
Posted on Jan 28, 2009
  • 752 Answers
The delay is normal as it's designed to create a spacious large room sound. The buzz however, is not. It sounds like the power supply is bleeding into the amp and should be serviced.
Posted on Sep 22, 2007
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
How to find a window fan that can be taken apart to be cleaned
I use this kind as a window fan and it’s great and easy to clean. Very inexpensive too.
Nov 16, 2017 | Miscellaneous
I can't get my rear left speaker to work for my LG LHT854
you bought it new ... every new prodycts should come with warranty therefore best advice take it down to where ever you bought it from
May 30, 2017 | LG LHT854 Theater System
When you put fader to rear theres no sound its a sony 6stack cd player sony6000
Check to make sure your wires are hooked up right. A good way to check your wires is to pull the cd player out. unhook - and + to right rear speaker. Touch the - and + to corresponding ends of a AA battery. Have someone in the trunk to see if the speaker moves. If it doesn't, replace your wire going back or maybe a bad speaker. if it does move and you hook it back to the cd player right, and there is still no sound...it is the cd player. Best of luck to you!
Feb 05, 2011 | Car Audio & Video
The screen keeps flashing rear chk and the rear speakers are not making any sound.
I had the very same problem, and found that if you power up the receiver in DVD/CD mode, or tap the function button to display DVD/CB mode, the Wireless Rear Speaker AMP will automatically recognize and turn on the sound. This work around was not posted anywhere in the manual, just 1 of many workarounds I have had to put up with this system to work. Right now my fan went and it just keeps shutting down, I have had this system for about 15 months and very disappointed with the quality. My DVD player stopped working a few months ago, so now the system is rendered useless, not even sure it is worth fixing at this point since it is no longer under warrenty.
Jun 29, 2010 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Our Philips HTS3400 DVD player is not working. When inserting a disc, it displays "No Disc". Any suggestions?
seems to be an issue with this model, i cant play any discs, the sound is only coming from the left rear speaker and the sub, the system shuts off every half hour due to overheating...needless to say the system sucks...didnt last long...im very tech savvy and still couldnt figure out why all of this was happening.
im looking at samsung now...everything else i have is samsung and love it.
Dec 31, 2009 | Philips HTS3400/37B System
MY SAMSUNG HT-Z310 HOME THEATER SYSTEM COMES ON AND SHUTS DOWN WITH PROTECTION ON SCREEN AND SOMETIMES COMES ON PLAYS MUSIC BUT SLOWLY LOWERS ITS SELF THEN U CAN STILL HERE IT BUT VERY LOW PLEASE HELP ME...
I had the same problem. It turns out one of the speaker wires was pulled out from the speaker and the and -ve were tangled. Once I separated them and put them back in the speaker, the system started working fine.
Oct 11, 2009 | Audio Players & Recorders
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Sep 09, 2007 | Pioneer DEH-P3800MP CD Player
Sharp sd nx10_out signal trouble
Try all of the spaekers on the channel you know works. If all are fine, swap the speaker lines to test them. Is the input a DVD player on RCA cables? A bad signal cable from a component can be a source for problem. Connect the speakers directly to the amp(if possible) bypassing the sub box. If all works without the box, suspect bad crossover or in the self-powered boxes a bad amp.
Jun 22, 2007 | Sharp SD-NX10 CD Shelf System
RTD170 Speaker Problems
Have to change the set up in the menu section and make absolutely sure it is on surround dolby and not stereo. Check manual for set up.
Jan 01, 2007 | RCA RTD170 System
Aiwa NSX-DS55 CD Shelf System Logo
176 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
