Question about Compaq Presario 5000 PC Desktop
PC won't boot, Black screen,Low Virtual memory message.
My Presario PC won't start up. It starts to boot up, Then it gets a black screen and a message box saying ''Windows Virtual Memory Minimun Too Low''
I am running XP.
Cant get anything?
Thanks for any help.
  • 741 Answers
Yes you need to get to the Virtual Memory Page and Increase your Virtual Memory. Try this: Reboot and hit F8 which will put you in Safe Mode. Click Safe Mode and you will be back in Windows. Click on Start>Control Panel>Administration>Click on Computer Management>then right click on Computer Management and click properties. On the bottom you will see Performance open that Window. Then on the bottom of that you will see Virtual Memory. Click to increase. It should be at least 10% of your total harddrive maybe more if you don't have a lot of memory. Reboot. Let me know how it comes out.
Posted on Jan 04, 2009
  • 127 Answers
Reinstall your Windows
My Medion laptop won't boot windows; black screen
Unplug, remove battery, Remove and reseat Memory Mods, try to reboot. If no, Remove HDD and test, replace if necessary. Has their been any damage? Dropped?
Feb 02, 2013 | Computers & Internet
Hi. I have windows XP 2007. Each day, when I first log on, a message says: "Virtual memory too low. Windows is increasing memory on your paging files." This takes an hour. If I reboot during the same day,...
Google "virtual memory too low solution." Trusted sources are PC Magazine, Microsoft...
(In my case, I ran "msconfig", go to "Start up" tab and uncheck programs I did not want Windows to load at boot. That would free up memory.).
Aug 22, 2010 | Computers & Internet
I purchased the laptop(Pavilion dv2000) in Jan. 08.This evening, I closed my laptop without turning it off, but 20 minutes later, when I opened it, it was black screen. I turned it off and turned on...
Reboot the computer and when you here the motherboard tone, tap the delete key to see if you can get into the BIOS screen. If the delete key does not work, try F2. If you can get into the BIOS, then there is a chance it is simply a case of a bad setting. Go to the system default...which is probably on the last page of the BIOS screen. Click set default settings and then F10 to save and reboot. Try letting the laptop boot normally. If it does great, if it doesn't, try tapping F8 on a reboot after the sound and see if you can get into the multi-boot menu. If you can see the menu, boot into safe mode with networking. If it does boot into safe mode, try to update the video driver. Go to control panel > device manager > scroll down to video adapters and right click on the adapter listed and update driver. After it is finished, try to reboot normally.
Sep 25, 2009 | Computers & Internet
Trying to boot up my Windows XP PC - Vaio. Getting error messages that virtual memory is too low, then when I click that away, the screen is just black and I can move the cursor around, but that's it.
If you have at the least 512m of RAM, your laptop should boot without any virtual memory. Anyway, virtual memory is a method of using your hard drive to function as RAM, though much slower. When you have very little RAM, say less than 128m, and without enough hard drive space, you system will not boot.
If you have 512m of RAM or more, your problem maybe more complex to resolve. How much RAM do you have? How big is your drive?
What you need to do next depends on how much RAM you have.
Sep 11, 2009 | Computers & Internet
Blue screen on start up
This may be related to faulty memory or your page file (virtual memory) may be damaged.
You can try to remove your ram chips one at a time (boot up) and see if one is bad or make sure your virtual member is set to system managed.
To change your VM settings follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. Click the Advanced tab.
  3. Under Performance, click Settings.
  4. Click the Advanced tab.
  5. Under Virtual Memory, click Change.
  6. Click No paging file. Click OK, click OK, and then click OK.
  7. Restart your computer.
  8. Click Start, right-click My Computer, and then click Properties.
  9. Click the Advanced tab.
  10. Under Performance, click Settings.
  11. Click the Advanced tab.
  12. Under Virtual Memory, click Change.
  13. Click System managed sized. Click OK, click OK, and then click OK.
Apr 27, 2009 | Computers & Internet
Low Virtual Memory problem
For some reason your CPU is not using your RAM for memory. It is going to the .pagesys file, which is a file on your hard drive that holds Virtual Memory. Virtual memory is only used when you run out of RAM. So here are your choices.
You are going to need to buy a copy of Windows XP or whatever operating system you want. Then you try two things: First Format your current hard drive to wipe it clean and reload Windows XP. That should clear up your problem if it is a software issue. If that does not work then it is a bad hard drive (but I don't think it is).
If it is a hardware issue, your hard drive is corrupt, then you will need to install a new hard drive and then partition, format and load WIndows XP. Either one of those options will get you running again.
Please rate this solution.
Jan 09, 2009 | Compaq Presario 5000 PC Desktop
I get "virtual memory low" message and cannot boot.
The real solution to this is going to involve spending some money to buy some new memory. It should cost about $30-50 depending on type and amount. 256Mb is not enough for Windows and other software to run. I would recommend buying at least 512Mb additional to add. Before you purchase open up your machine and look to see how many memory slots you have and how many are currently used. According to some specs on the internet, here is what you have.
Maximum Memory 2GB Memory Slots 2 (1 bank of 2) Install in pairs non-removable base memory 0MB Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds. Please check the speed on the memory modules currently installed, or use our "Check Your Computer" to find the correct module.
It is simple enough most anyone can do this themselves, and I could walk you thru it, otherwise you would need to take it somewhere, but my recommendation would be to do it yourself and simply ask me or others here for advice. Let me know if you want help to do this.
Good Luck!
Dec 13, 2008 | Dell Dimension 3000 PC Desktop
No screen on starting laptop
try to re-seat the memory, the memory might loose
Jan 20, 2008 | Compaq Presario X6000 Notebook
Internet explorer not opening (memory problem?)
if your system is running low on memory, the pc will not be able to run the programmes as normal as it will use virtual memory which enables the system to open up programmes that you use regularly without searching for the start up files reciding on the hard drive, but if your system is low you will get these screen messages. Either upgrade the system with more memory or check what programmes you have running on start up using your memory, press start>run, then type msconfig and look at the start up tab and untick any unnecassary programmes that start up,then click apply for a restart, as this will release some of your memory. On the other hand there may well be a problem with internet explorer itself also, so you can download the latest IE7 from microsoft if you wish and see if this solves the runtime issue
Aug 24, 2007 | Toshiba Satellite M55-S331 Notebook
Compaq Presario 5000 PC Desktop Logo
171 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
