Question about Microwave Ovens
My microwave - Model: NN-H765/H965/SN776 reads
  • 93 Answers
SOURCE: I have a Panasonic microwave
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Posted on Jul 24, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: my microwave nn-994s smell burning and is working
Due to the lethal voltages used and produced in inverter-based, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Aug 20, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: purchased a panasonic NN-H965 microwave and
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Posted on Aug 30, 2009
SOURCE: Panasonic microwave model NN-2959: can't open door.
Your DOOR LEVER probably is broken. To open the door remove the filter (2 screws at the top) then remore the control panel by removing the screw holding it in place UNPLUG THE MACHINE. then unlatch the door. BUT I am trying to find a door lever and find they are no longer availabel.
Posted on Dec 21, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Model NN 9804 U microwave in Demo Mode
No owner's manual?
If you're in the US, find it here.
If you're not in the US, see Panasonic.net and look for support / download links.
Otherwise, I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Posted on Jan 16, 2010
What do i do about the tirntable not turning
first open door an take a good sniff see if you smell any burnt smell it could be a burnt out drive motor or a broken wire there are repair shops that do that DO NOT TRY AND FIX YOUR SELF read the warning panel
Jul 11, 2014 | Panasonic NN-H965 Microwave Oven
Replace light bulb panasonic h965
can easily pulled out from pin type socket..
Jan 29, 2014 | Panasonic NN-H965 Microwave Oven
Panaonic nn 1000 gs 597 no working microwave
follow this steps and fix it. God bless you
No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models
Jan 23, 2013 | Panasonic NN-H965 Microwave Oven
Model nn-n765 Was running made a scrapping noise then shut down now completely dead won't start no lights nothing
A wild guess: the scraping noise was a motor bearing seizing up (fan or turntable). A thermal cutout blew when something overheated. This would have taken several minutes to happen.
Alternate, and more likely explanation: the scraping noise was actually high-voltage arcing in a failed component, most probably the voltage doubler capacitor. This would blow the fuse. Replace both the capacitor and diode; the diode was probably overloaded and could fail at any time if it hasn't already. At $5-$10, it's cheap insurance against having to fix the thing twice.
Jan 18, 2011 | Panasonic NN-H765 Microwave Oven
Glass turntable
PANASONIC WILL SELL YOU THE PART ALL YOU NEED IS YOUR MODEL NUMBER
Dec 07, 2008 | Panasonic NN-H965 Microwave Oven
Trim kit
These are countertop units. If you do enclose it, be sure you ventilate it adequately. If is not designed to be enclosed.
Dec 15, 2007 | Panasonic NN-H965 Microwave Oven
Microwave shuts down after 5 seconds
chech the control panel and wiring and thermal sensors..
Sep 23, 2007 | Panasonic NN-H965 Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
