How do I remove a keyboard from a Compaq HP G5000 Notebook. Please, any help would be very much appreciated before my laptop learns to fly.
I need to replace my keyboard and cannot find any instructions or manuals anywhere. I need a new battery but I can see that is simple to replace. Any help gratefully appreciated.
  • 731 Answers
Hi:) I found a manual PDF Just goto this link
http://www.hp.com/ctg/Manual/c00212209.pdf
There is a disassemble section GoodLuck
Posted on Nov 02, 2012
  • bevfish
    bevfish Nov 02, 2012
    Thank you for the link Chris, unfortunately that is not the same, the layout, casing and internal screws are very different - I have made extensive searches and it is an Compaq/HP G5000 (possibly CTO) = the keyboard is not as simple to remove as on most models of laptops - I have had nearly all the pieces out and it seems impossible to find find the screws that hold the keyboard in place. Thank you for your link, time and trouble. The search continues.
SOURCE: HP DV 1000 Keyboard Replacement
to get old keyboard out you need to take battery out of back and there will be 2 screws with a keyboard symbol by them unscrew them and then just pop the keyboard out
Posted on Apr 10, 2008
  • 58 Answers
SOURCE: acer aspire 5920 keyboard replacement
http://www.gadgetsmanual.com/aspire-5920-series-users-guide.html THat should be whatcha looking for. Good luck!!
Posted on Jan 11, 2009
leecom72
  • 4806 Answers
SOURCE: How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Posted on Nov 13, 2008
benwabnick
  • 2404 Answers
SOURCE: Replacing lcd screen on HP dv4-1120us laptop
Here is one place I found thru google that sells your lcd for your laptop:
http://base.google.com/base/a/1453857/D14569028068669548660
Price is about $89.00 before any S/H charges. I'm sure if you do some research you may find them cheaper.
When it comes to replacing the lcd on these laptops most of the time its done the same way. Unscrew the screws on the front lcd bezel and then remove the bezel so it will expose the lcd with a hinge on each side.
Remove the screws on the left hinge and also remove the screws on the right hinge.
At this point the screen will be loose. Disconnect the power connector from the bottom of the lcd that goes to the little rectangular inverter board.
There will also be a cable on the back of the lcd screen that needs to come out as well. Be gentle with the cable cause its sensitive.
At this point you can remove the bad lcd and then get ready to put the new lcd into place.
Go ahead and connect the lcd cable to the back of the lcd, don't worry it is slotted so it can only go in one way and it will kind of snap into place. Then go ahead and align the screen with the left and right hinges so you can put the screws back on so it keeps the screen in place.
Then go ahead and connect the power connector to the rectangular inverter as well. Now that you have the screen hooked up. Turn on the laptop and if you get video then you know the screen is good, turn the laptop back off and then go ahead and put the lcd front bezel back on and put the screws back into place and you should be good to go. I know this was lengthy but hope this information helps.
Posted on Jun 18, 2009
SOURCE: how can i reset CMOS/BIOS password for HP compaq tc4400 laptop
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
Posted on Apr 16, 2010
Hp g5000 sreen does not light up as usal, i can see a the start up when i shine a torch at the sreen, what do i need to do to get working.
An LCD screen cannot produce enough light by itself. It needs an additional source of light.
A Backlight is used as the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to the Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
The LCD screen is a composite of layers, surrounded by a thin metal frame that resembles a picture frame.
To one side of the LCD screen layers, and under the frame is usually where the Backlight is mounted.
[Note* Two Backlights are used in some models]
Replacing a Backlight is more labor intensive than replacing an Inverter.
Due to this, and the cost, the LCD screen itself is replaced as a unit most of the time, when it comes to Backlight replacement.
Example of a replacement LCD screen for the HP G5000 series of Notebook PC's,
https://www.screentekinc.com/HP_G5000_Series--15.4-inch--1280x800-wxga-laptop-lcd-screen.shtml
[Note* Stating HP G5000 is just stating the model series. When buying replacement parts the EXACT Model Number should be used. This information is located on the bottom of the laptop, in a white Service Tag.
When replacing an LCD screen, the model number of the replacement LCD screen should be matched to the existing LCD screen's Model Number.
Inverters and LCD screens are matched together. Make sure you get the correct part]
An Inverter is used to provide power from the laptop to the LCD screen, and to the Backlight.
Note* 90 Percent of the time the problem is a bad Inverter.
Example of an Inverter for an HP G5000 series notebook PC,
http://www.zlectronic.com/product/INVERTER-FOR-HP-DAC-07B035-DAC-09B017-DV5000-G5000.html
The LCD screen, Top Cover, Display Bezel, Inverter, Backlight, and various screws, make up the Display Assembly.
The Display Bezel made of plastic surrounding the LCD screen, and in front of the LCD screen is removable.
Behind it is easy access to the Inverter.
The Inverter is approximately 4 inches long, and the width of a No.1 pencil.
Usually located at the bottom of the LCD screen, and right behind the Bezel.
This article shows replacing an Inverter and LCD screen on a Compaq Presario v2000 series Notebook PC,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-compaq-presario-v2000-laptop/
This pictorial guide is not for the HP G5000 series Notebook PC, but the models are very similar when it comes to Inverter replacement.
The above link is to show you what is involved.
Please post questions in a Comment.
Regards,
joecoolvette
Apr 03, 2011 | Computers & Internet
I Need Help Unlocking My Hp Compaq 6910p Every Time I Turn It On A Blue Screen Pop Up And It Say POWER ON PASSWORD .... PLEASE ANYONE HELP ME UNLOCK MY LAPTOP!!!!
Unfortunately HP says: "If you forget the power-on password, the computer must be reset at an HP-certified repair center. Please contact HP to schedule a repair. The Drive Lock password cannot be reset. If you lose or forget the Drive Lock password, the hard drive must be replaced. Please contact HP to order a new hard drive. These services are not covered by the warranty."
Sep 13, 2010 | HP Compaq 6910p Notebook PC PC Notebook
I have a laptop hp Compaq 6910p, and by mistake I ...
Its too risky for a user to open the laptop, access the mainboard and reset to its factory setting..
Very dangerous for the hardware too..
My suggestion is to bring your laptop to a credible technician to open your laptop, reset the cmos to its factory, and return the cover properly..
Hope you understand.
Much appreciated if you rate this help.. thanks
May 20, 2010 | HP Business Notebook 6910p Notebook
Removal of keyboard
Here is the service manual for your printer:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01293339/c01293339.pdf
page 50 of the manual shows you exactly how to remove the keyboard from your laptop.
May 16, 2009 | HP Compaq 6720s Notebook
Access to ram
The n610c has RAM accessible from underneath the laptop. There will be a cover with a logo looking like a computer chip near it. Should be 1 screw to access it.
Feb 05, 2009 | Compaq Evo N610C Notebook
Replacing the keyboard on a compaq presario v3000
Here is a link to the Service Guide for the v3000z. The information regarding removal of keyboard starts in section 5.10 page 5-21.
Hope this helps. Please remember to rate this information.
Thanks
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
How to replace the Keyboard?
if you are not sound on technical ground its better to be done by the technician
Oct 17, 2008 | HP Compaq 6910p Notebook
Keyboard not work
Hello ,
As per what i understand from the issue you stated it has the possible solutions :
1. perform a Power Drain Test to drain out the accumulated static charge from within the notebook (happens with every laptop) - let the laptop be on , remove the power cord , remove the battery directly without directly shutting the laptop. The laptop will shut down once you remove the battery. Then press and hold the power button for the next 50 seconds continuously. Then attach the battery , then the power cord and power on the notebook. Check the keyboard . If no go , then
2. use an external keyboard . Attach the external keyboard to the laptop and boot into the normal OS desktop. Open Device Manager and check if there are any conflicts. Or else directly update/flash the BIOS by clicking on the link below :
www.hp.com
If unable to do so , please mail back giving the Serial Number of the laptop and the Product Number (loacted underneath the laptop on a white label beginning with s/n and p/n respectively ) and i shall send you the exact BIOS update/flash link .
Regards ,
Puloma
Aug 02, 2008 | HP Compaq Presario 2200 Notebook
Removal of laptop keyboard
Dear ctmom
Please find below the link to download the
HP Pavilion zx5000 Notebook PC, HP Pavilion zv5000 Notebook PC, Compaq Presario R3000 Notebook PC, HP Compaq nx9100 Notebook PC - Maintenance and Service Guide
( http://h10032.www1.hp.com/ctg/Manual/c00212209.pdf )
Removing the keyboard firstly requires the removal of the top plastic strip in order to gain access with the screwdriver to the four screws. To remove it follow the instructions at pages 137 & 138 and you are almost there.
Then on page 139&140 you will find the information to remove the keyboard. It explains all the information very analytically. You are simply unscrewing the four screws on the top side. On the bottom it is simply slided.
TIP: Be careful when you are releasing the keyboard up towards you. The flexi cable that is connected to the motherboard is quite short-fragile and does not have a lot of space to move so go slow until you have released the connector’s tabs and the cable is loose to be removed.
Please remember to remove the battery before you do any work in the laptop.
Mar 17, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
891 people viewed this question
David Payne
David Payne
