Question about Refrigerators
Samsung refrigerator rf4287 power out for 5 days when power came back up display screen flashing 1 (or I ) and letter E
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
The IE error code is actually 1E. That stands for freezer sensor error. The sensor is reading open or shorted to the main pcb. You need to check the wire connections, from the sensor to the main pcb. I provided you a sensor temperature chart and wiring schematic on the images below. You will need a multimeter to perform the voltage checks. I hope this helps.
Image 1
Image 2
Image 3
Posted on Nov 03, 2012
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Samsung Cool Tech Dynamic not cooling properly
Alan if the power was off for less than 5 minutes the compressor high pressure went to the low side and the compressor just will not start. The thermal overload Klixon will click about every 8 or 9 minutes and the compressor will not start.
Unplug it for about 30 minutes and then plug it back to see if it lites off and runs correctly.
As for the control panel... (fingers crossed) hopefully it is a symtom of the compressor not starting. Again unplug it for 30 minues and restart it after that. It just may get things back to normal without any repair service.
Posted on Jan 23, 2010
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
Samsung refrigerator freezer model RF4287 has OF codes showing on both freezer and refrigerator. Cannot reset by unplugging for 3 seconds or pressing codes for three seconds. How can this be fixed
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Ok, on the left hand side of your refrigerator display board there are two selector buttons. Press on both at the same time for 3 seconds. This will take you out of the OF mode.
Apr 19, 2015 | Samsung Refrigerators
Water is coming under freezer section of Samsung RF4287 bottom freezer French Door
You have a plugged evaporator (cooling coil) drain pan opening or drain line.
Feb 06, 2015 | Samsung RF4287HA
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
Samsung refrigerator has OF code on display and is not working
The letters "OF" on the display of your unit indicates the Cooling Off mode has been activated. To cancel this mode, press the Power Freeze and Freezer buttons simultaneously for 3 seconds until a chime sounds and a numeric reading returns to the display, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air.
Nov 06, 2012 | Samsung RS2630SH Side by Side Refrigerator
Samsung refrigerator is not working OF code on display
Keep me posted!
Nov 06, 2012 | Refrigerators
Samsung rs2530 screen went blank except 1 lights bar flashing on freezer and wont cool
The one light flashing on the display is an error code. Depending on which light is flashing will tell you what the error code is. Check the link below to see if it has the error code. That should give you an idea of where to start.
Samsung Error Code List
Mar 16, 2012 | Samsung Refrigerators
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
May 16, 2017 | Samsung RS265LBBP Side by Side...
Samsung model rs267 says OF on both temp displays
Freezer and refrigeration isn't working
There is no temperature indicating for Celsius of Fahrenheit it just displays OF.
The letters "OF" on the display of your refrigerator indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and the display returns to normal, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air. Thanks-Helpful?
Feb 07, 2011 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerators Logo
220 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
