Question about GE Washing Machines
My washer is leaking from the bottom its seadly getting worse please if any one can help let me know
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 03, 2012
5 Suggested Answers
chris0fer
  • 5 Answers
SOURCE: My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Posted on Jun 19, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore top load portable washer leaking, model 110.42722200
Replace the water pump. The seal is leaking.
Posted on Jul 16, 2009
SOURCE: Water leaking from the bottom of the washer
You need to also check the lower drain hose from tub to pump. It is called bellows. I have had to replace mine twice. I have wm2077 model. they are about $20.
Posted on Oct 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: started leaking from the bottom don't know where
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Our washer is leaking water out of the bottom. Checked the hoses and its not coming from any of them. The water seems to be coming from the right bottom side.
A leaking washer can have several causes. In order to be able to accurately determine where the leak may be coming from, you will need to remove the exterior washer case to get a full view of all the interior washer components. The following link explains how to perform this procedure and what to inspect for:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If you have any questions about any of these procedures, please post back and let me know. I hope you find this information helpful.
Nov 10, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore elite. Loosing water from bottom only when in use.
If your FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or if your washer is NOT a FRONT LOADER, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: The leak may appear to be worse with heavier loads, because more water is in the drum and it is being displaced by the laundry load.
Jun 25, 2010 | Kenmore 24032\24036 Top Load Washer
Toilet tank to bolt repair has make the leak worse
Rubber goes on the inside. Might be an optional laarge flat washer and nut on the bottom (outside)
Feb 21, 2010 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Bosh Washing Machine leak
Regildg,
No, I have not fixed it. I can see the water dripping off what appears to be electric motor plates hanging low on the bottom of the washer.
It does seem to leak most right after I have used the machine.
The drip is not getting worse and appears to be about the same.
Jun 29, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water leaks from underneath washer
my washer is leaking with water on floor.it is now geeting worse. the washer seems to clean fine. my floor is gettig ruined please help
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
26 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
