Question about Whirlpool LER4634J Electric Dryer
No heat replaced element'hi limit therm.'cycling therm'and thermal fuse along with in-line transformer,still no heat
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Check the breakers and make sure you are getting 220v to the dryer. That is all that is left to check. One of the breakers must be thrown.
Posted on Nov 03, 2012
Illeagle
  • 525 Answers
SOURCE: Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
protek480
  • 1723 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 12, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
hiltonjug
  • 612 Answers
SOURCE: LER4634EQ2 whirlpool electric dryer. heating
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Posted on Oct 10, 2009
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
Whirlpool dryer overheats, heats on air only
Sounds like heating element may be grounding out.
Oct 27, 2017 | Whirlpool Dryers
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Hi, Our dryer runs but doesn't heat. We checked the power source, heating element with ohm meter but it was fine. What else should we check? Thanks.
Hi.
If the dryer runs there is no problem with power. If the appliance runs but does not heat the problem is one of the thermal devices. The dryer comprises one thermal fuse, several thermostats and the element. Thermal fuse and thermostats must be checked along with the element.
Start from the thermal fuse. The fuse can be tested reading impedance with a multimeter. If the fuse is open it will read Ohms infinity. In that case replace the fuse. Here the part: ASSY-BRACKET (THERMOSTAT) (Thermal Fuse with Bracket).
The fuse is part n.15 in Diagram one below. Click on the picture to enlarge:
If the fuse is OK, or if replacing the fuse did not help test the thermostats. You have the following parts:
THERMOSTAT - Part 11 in diagram
High Limit Thermostat -Part 13 in diagram
THERMISTOR - Part 27 in diagram
If the appliance is running the door switch should not be the problem. If you need test also the DOOR-SWITCH.
The thermostats can be tested reading impedance. If there is no heat, then one of the thermostats is open and will return Ohms infinity. Other way to test a thermostat is by jumping its contacts and running a controlled cycle to prevent overheating.
Regards.
Ginko
Aug 09, 2011 | Amana NED7200TW Electric Dryer
Dryer had built up lint,blew fuse,now will blow fuse after cleaning and replacing vent hose
if its heated electrically, not by gas,then it sounds like the heating element has shorted to the case and this would blow the breaker
Jul 28, 2010 | Amana NDE2335AY Electric Dryer
GE stackable dryer not heating but it is running. I do have 240 volts at the outlet thank you
check the hi-limit and cycling switches on the element case along with the element itself for continuity,then if these are o.k. then check the thermal fuse on the vent pipe conduit inside the dryer near the vent connection as this is in line with the element and this opens up the element cant heat
Mar 27, 2010 | Dryers
No heat from my tumble dryer
There should be 2 limits mounted above the heating element on back along with a limit mounted on the heating element. I have some repair video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 16, 2010 | Zanussi TC7102W Electric Dryer
Kenmore dryer Model 110.86982 Year 1989 does not heat
If you bypass the hi limit thermostat you will blow your thermal fuse within minutes. The hi limit thermostat is a bi-metal thermostat which warps when heated to kill power to the element. If its bypassed then the element will not turn off.....which will in turn blow your thermal fuse which is rated at a higher temp than the hi limit. So unfortunately it will not work.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Dryers
I have replaced the heating element and cycle thermostat on my electric dryer but it still does not heat
have you checked the hi-limit switch on the heating element case, then the one shot thermal fuse in the line also
Nov 17, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
