SOURCE: Will fill with water but during rinse and spins it won't drain.
I fixed it on my own. By taking off the suction hose and spinning the fan inside it apparently dislodged something and is working now. Hopefully the problem won't come back, I was unable to find the foreign object.
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: Washer will not Spin during SPIN CYCLES
IT IS THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE, THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. I FIXED MINE MYSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY, BUT I SAVED MYSELF $250.00. YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE.
SOURCE: Washer won't spin or drain water
you checke dthe drain??? how??? i would assume that you have something stuck within your drain pump assy( bra underwire-- money--- toothpick--nail/screw) VERY common issue, youll need to remove the front cover and remove the hose leading to the pump to look inside. DISCONNECT POWER-- PUMP IS ALWAYS LIVE!!!!!!!!!!!, oh yea and youl need a bag to collect the water when you disconnect the hose, YOURE GONNA GET WET!!
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
