Question about Acer TravelMate 4740
Hinges broken while opening - Acer TravelMate 4740
    Problem Solver:
  • 12 Answers
I have fixed one by replacing the scews on each side my kids like to carry it around by the screen , you may have to put a small washer to hold the screw from going in to far try it good luck don
Posted on Nov 02, 2012
Why won't my hinged cupboard door stay closed?
Depends on type of hinge, If it swings back open after you closed it then either the cupboard is not level (old style hinge)...
Or the spring inside hinge is bad/broken and not holding it closed. If the door opens back just a bit (1/2 inch or so) see if hinge has adjustable screws.
Oct 15, 2016 | Top Knobs Hardware & Accessories
Acer aspire 5253 power button broken due to hinge
Have a repair shop or person look at this---it may be fixable now but if you keep using it the issue may get worse.
Nov 05, 2012 | Acer Aspire 5532 15.6" Laptop Original...
Front loader door hinge broken
What is the model number of your unit?
Nov 05, 2012 | Maytag Washing Machines
Broken hinge
Not that I know of. They are easy to replace, check out these WEB sites.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Sep 07, 2012 | HP Pavilion dv9005us Notebook
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
Door open warning
Yes, the doorjam switch is either shorted or broken. This switch is on the cabin door opening by the hinges. In rare cases the pin may be self adjusting. Sometimes you can press in the pin by hand to see if it shuts off the interior light. Do not slam the door with your finger in the hinge area.
There may be a problem with the door adjustment or the hinge may be broken and you do not know it. It can be a lose or broken wire inside the cabin shell.
Feb 12, 2012 | 2004 Mercedes-Benz C-Class
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Acer TravelMate 4740 Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
