Question about Tripp Lite SMART1500XL 1500VA 980W UPS Smart Tower AVR 120V XL USB DB9 for Servers 6 Outlets
Fan cycles on and off whats the problem with no load 1 min on 1minute off.
  • jim valley Nov 07, 2012
    We have over 30 each two of which developed this problem, so i'll troubleshoot the control circuit.
  • Wayne Holden Nov 08, 2012
    Could be an aberration in the electronics since you have 30 examples to judge against! Not every sensor is the same until you get into precision ones and they cost big bucks. Hope they function well enough to do the job.
  • 512 Answers
Electronics generate heat, as long as the fans do come on and keep it cool, it is functioning correctly. If you load it and they stay on longer there is no problem. If they don't, it may have a melt down so check it with a load and if they are not staying on longer, provide some cooling yourself.
Posted on Nov 05, 2012
The normal and casual cycles are not working. The wash time shows 1:20-1:32 when I try to start it on these cycles and when I start it the machine will toss the clothes without water and then will show...
Hi Rob, thank you for allowing me to assist you!
Based on the symptoms you are describing it sounds like your washer is possibly experiencing an issue with the control board or a faulty door switch. It could also mean that the wiring between these two essential parts has gone bad. In cases like this, I strongly recommend connecting with a local appliance tech that has the expertise to distinguish which part is the culprit. I hope this information proves useful.
Oct 26, 2013 | Frigidaire Affinity ATF7000E Front Load...
My 02 Camry v6' battery was removed for 30 min and put back on - good battery. Engine starts no problem but stalls at idle. No error code. Is a computer-code reload or IAC cleaning ? Seems the car computer...
idle learn procedure:
turn off all electrical items (AC fan, audio, lights, defogger, etc.)
Start the engine and hold it at 3,000 rpm with no load (in park or Neutral) until the radiator fan comes on or the engine coolant gauge shows normal running temp.
Now let the engine idle for a minimum of 5 mins with no electrical loads. If the radiator fan cycles on during this time, you must add the fan running time to the 5 mins.
Feb 10, 2011 | 2000 Toyota Camry Solara
Compressor fan mtr hot, hear it try to energize for approx 2 seconds then stops aproximately 1minute later cycle repeats, removed coil voltage and manually acuated coil did not hear anything trying to...
The motor bearings have siezed up and the motor needs to be replaced...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 22, 2010 | Goodman CPLE24-1 Air Conditioner
Washer goes through 40 min. cycleand stays on 1 min. spinning and rinsing for another 30 min
your using way to much soap
during that whole 1 minute cycle it is detecting suds and trying to rinse the cloths further
cut way down on the soap here
you should be using 1 tablspoon per load
wash one load without anyy soap at all
this should help to reduce your suds lock
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Time remaining stays at 1 min for 20 min
This may happen if using the Super-eco program.
It is designed to extend the washing time / cycle, but is less intesive in rotations. It's more a long gentle soak than a quick scrubbing action.
Thank you for using Fixya! If this provided a solution, please rate as such. Thanks.
Jan 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Tripp Lite SMART1500XL 1500VA 980W UPS Smart Tower AVR 120V XL USB DB9 for Servers 6 Outlets Logo
111 people viewed this question
Top Tripp Lite Electronics - Others Experts
Are you a Tripp Lite Electronics - Other Expert? Answer questions, earn points and help others
