Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Refrigerator whirlpool Model ET1PHKXPT00
Water and ice found under bottom crispers
SOURCE: water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
Sea Breeze
  • 4655 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
mgprice
  • 744 Answers
SOURCE: water pools under the veggie crisper
yoor problem is with the drain, when your refrig goes into self defrost the water melted from the defrost needs some where to go. There is a drain for this purpose....it is normally a tube that leads from the rear of freezer to pan by compressor. when this gets blocked the water has nowhere to go except into the freezer vent and down the bottom of the refridge compartment. you will need to clear the blockage in the drain tube...if you are still haveing a problem i can tell you how.
Posted on Jun 22, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
toolkits
  • 1099 Answers
SOURCE: My Whirlpool refrigerator is leaking and water is
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Hope this helpout,
Posted on Jul 28, 2010
Whirlpool refridgerator with top freezer. Water leaks and pools at bottom of refridgerator under crisper. How do I fix the leak?
Here is a Utube video that will do the trick. Might not be your model, but same gig.
https://www.youtube.com/watch?v=VHD556AQ894
Dec 22, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
2006 Whirlpool 20.9 cu ft, freezer on top, model # 60192ET1chm Water is going into crispers and under the crispers. Problem is ?
If you access the panel in the rear of the unit, check the evaporator tray, is it dry? It shouldn't be! If so, check the drain hose above it. It is likely plugged.
Jan 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in bottom of fridge and in crisper drawers
the defrost drain in the freezer is clogged with ice.
empty the food from the freezer, and put through a defrost. you might have to help the fridge defrost with a hair dryer. you may also have to remove the rear panel (inside the freezer) or pending on the model to bottom panel of the freezer.. (usually held in by 1/4" hex screws.)
melt all the ice, and be sure that the drain is clear, and it should work.
May 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in the bottom of the refrigerator
you have to take out the back postion in side the freezer please ulplug the refrigerator under the evaparator is the drain throw hot water in there
Mar 30, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
106 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
