Question about Star Micronics TSP800II Thermal Printer
Printer reading an error
Rebooted printer after power outage and just keeps flashing an error
Amber and green light keep flashing back and forth, not printing. I tried rebooting, nothing happens
Switch off the printer and disconnect from the power supply. Leave for 10 minutes and then try powering up again from cold. If you are still getting flashing lights please count the number of each flash and repost
http://www.retrevo.com/pdf/262dj183/24/Handling+Error+Messages#q=Canon+i560
Mar 01, 2011 | Canon BubbleJet i560 InkJet Printer
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
Cx4200 epson printer, make noise, feeds paper but comes out blank. Have checked the ink on the cartridges and clean the nozzle heads. Left it unplugged over night
I don't know if the problem was fixed by the update or simply the reboot. (Rebooting just the printer had no effect.) Also, FYI, there had been a power outage right before the problem started, but I'm not sure how that would affect the issue, unless maybe the Mac had installed some problematic software during the reboot that obviously occurred after the power outage was resolved. Sometimes software updates don't complete until the next reboot, and she may have downloaded some updates long ago without completing the process with a reboot. Just guesses, but hopefully some of that help you too.
Jan 21, 2011 | Office Equipment & Supplies
After power outage, printer displays not shut down properly and keeps rebooting.
Hold the "#" and "6" key down as it reboots. This is the equiv to a cold reset. However, I cannot setup my wireless now that I've done that done the reset. It immediately reboots and goes back into the same problem. So, has the wireless section gone bad??
Oct 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
Flash memory is not progammed
I would say the flash memory is faulty after the power surge/outage.
Sep 29, 2009 | Zebra LP 2844 Thermal Printer
Had a power outage, not a surge, now reads call for service.
Press "clear" and "8" simultaneously and hold, this should display the error code...what is the error code?
Jun 14, 2009 | Office Equipment & Supplies
Power outage caused printhead error on HP 1055 CM design jet
turn off the printer, remove your jetdirect card(nic) sounds like your local tech doesn't know his **** from a hole in the wall. this should resolve your loop problem, if not then your main pca have been popped by the power outage. good luck.
Apr 22, 2009 | HP DesignJet 1055cm InkJet Printer
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
Star Micronics TSP800II Thermal Printer Logo
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
