Question about Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
How to replace a drive on cub cadet model lt 1050 series 1000 year 1995
Need information on how to replace drive belt .
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Remove the deck and give yourself some room to work
Posted on Nov 22, 2013
5 Suggested Answers
  • 5370 Answers
SOURCE: how do you replace the drive belt on a Cub Cadet
Just click this link.And follow the step by step instructions as per mentioned to replace the drive belt on lt-1050:---- http://technoanswers.blogspot.com/2011/04/how-do-you-replace-drive-belt-on-cub.html ------------- This should help.Thanks.Helpmech.
Posted on Apr 10, 2011
  • 252 Answers
SOURCE: I have a 2007 Cub
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Posted on Apr 30, 2011
Testimonial: "This was very helpful thanks pauly 46 "
  • 252 Answers
SOURCE: need a transmission belt diagram for cub cadet
hi there
pauly46 here
cub cadet 1000 series
i can only suppose its a LT 1018 up ward
here is web site for that model
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1018+Tractor&dn=0125100003
or you can go to here and choose from this web site area list
http://www.partstree.com/parts/?lc=cub_cadet&mh=12
choose your model from list , then go to drive system
view belt diagram ,
you could save a copy or print them straight off web page
pauly46
Posted on May 01, 2011
tr68737
  • 20 Answers
SOURCE: I need a diagram for the blade drive belt of a cub cadet LT 1050
You can find a diagram here... www.partstree.com
but you will have to use the correct model number that is under the seat. Click on Cub Cadet, then enter the model number. That will give you all of that mowers diagrams
Posted on May 19, 2012
Testimonial: "thanks so much .... provided exactly what I needed"
How to replace drive belt on cub cadet 1050
Fairly easy to replace once the deck and the electric PTO are removed just make mental notes or rough of the belt path before removing the old belt. One thought if I remember correctly this uses 7/16" belt and a 1/2" width will not work due to the tight clearance at the engine pulley so stick with OEM belt.
Oct 14, 2014 | Cub Cadet Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling
Because I didn't know they used 2 belts in the diagram on parts tree.com . I bought the 79" belt and not the 78" belt.
Aug 22, 2014 | Cub Cadet Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
you need to change thr hydr fliud in the transmission and the filter
Cub cadet 1000 series LTX 1040 riding lawn mower
Check the pully alignments with a straight edge. Make sure the belt is tight.
May 19, 2013 | Cub Cadet Lawn Mower V belt Replaces CUB...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
Need a transmission belt diagram for cub cadet 1000 series
hi there
pauly46 here
view belt diagram ,
pauly46
Apr 30, 2011 | Cub Cadet Garden
I need an owners manual for a cub cadet riding mower. series 1000. model 1042 Lt. serial # 3430203833. thank you
Go to following site http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051 Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Mar 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
334 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
