Maytag model MFW9600SQO had a power outage ,now constant alarm and no lights on front
Tried unpluging for a minute then an hour then over night and re`-pluging and nothing but an anoying alrm that is constant. Whats up with that.. Boggled Guy. L
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
The main control board has gone out and will need to be replaced. All of the newer washers, and dryers that have the electronics need to have a surge protector on them. Here is the control board to order.
Posted on Nov 03, 2012
ginko
  • 19396 Answers
SOURCE: My whirlpool duet washer displays
F74 is not a valid fault code. If it was F14, then it was bad eeprom value (on timer board).
Try tripping circuit breaker or unplugging the power cord. Connect power back and follow reset procedure again, that will reset NVRam.
Ensure that there is no water inside the machine. If there is water, while machine is disconnected, empty water.
If that does not work, the control board may be defective.
Posted on Oct 09, 2009
  • 619 Answers
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Posted on Jan 09, 2008
Master_Tech
  • 770 Answers
SOURCE: dryer won't turn on
whats your email?
Posted on May 31, 2008
  • 351 Answers
SOURCE: My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Posted on Jun 16, 2010
Testimonial: "You confirmed my suspicion Thanks "
Jahn27
  • 1554 Answers
SOURCE: My Maytag washer MAV5920EWW is
The technician is right, the control board needs to be replaced. No such reset button for the control board. The only way it can possibly reset it is unplugging it for longer period to forcibly reset the microcontroller but there's no assurance that it will reset. Let the machine sit overnight before purchasing a new control board with part number 21002238.
Posted on Oct 05, 2010
After a power outage my maytag model MFI2569DEQ1 fridge display panel won't light up. Pushing any button lights up everything and 88888 across fridge and freezer temps...
Unplug it for a couple of minutes, Try again. It may have been hit with a surge. IF that is the case, you are looking at main control board and some money. Contact your homeowners insurance if a surge has damaged it.
Jul 31, 2017 | Maytag Refrigerators
After power outage for about 2 hours, my freezer wasn't freezing. high temp light and alarm came on. the compressor was humming but not kicking on. i unplugged it and i heard ice falling during the night....
call a repair service or go buy a new one . could be the starter on the motor but sadly we can not test it since we have no access to it
Feb 13, 2018 | Freezers
How do you set time and alarm?
If you unplug the clock, then plug it in again, the time should blink. Then you can use the volume buttons to set the hour. Press the Time button after the hour is set and the minutes will start blinking. Follow the same procedure to set the minute.
I have not figured out how to set the alarm time yet. Hope this helps.
Jan 06, 2014 | Hello Kity Hello kitty kt2052 sleeping...
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
Hi! After a power outage my Little Giant SPBS-12 backup system sounded an alarm that wouldn't quit even after power was restored (it was only off for an hour). When unplugged the louder and more...
What is the age of the unit? Those batteries don't last forever and are constantly under a small charge. When the outage happened the battery discharged and the sensing circuit was able to tell that the battery was no longer any good.
Mar 29, 2017 | Little Giant 506400 SPBS-12 Pump
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Power outage last night - alarm sounded. Turned off computer - pressed the button to silence alarm. Five hours later, battery sounded a different alarm every 20 minutes that could not be stopped. Gr-r-r-r!...
hi..OK 1st step open the unit and find the memory from the board remove the memory then make clean the all pin connectors using a paper eraser.if u have video card remove too then same make a clean..good luck and have a nice day...Thanks
Jun 14, 2009 | Tripp Lite Lite OmniSmart 700 PNP UPS...
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Dispenser Panel is not working
coundnt bring up anything on the model # Try Takeing cap hedge off freezer side unplug door power plug for 20 minutes see if that will reset dispence board .... works on ge... havnt tryed it with a maytag
Sep 07, 2007 | Maytag MSD2756G Side by Side Refrigerator
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
