Bosch logixx 8 no power How do I open door - Washing Machines
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
Posted on Mar 14, 2008
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Bosch washing machine (logixx
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: bosch logixx 8 washing machine showing F37
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Macmarkus
  • 2605 Answers
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Posted on Dec 22, 2010
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
Bosch error E23 flashing
disconnect the power the door unlock within 30 secound
Oct 12, 2014 | Bosch Washing Machines
I have a Bosch Logixx 8 1200 When i turn it on it bleeps and f 37 comes on but it is in a warm dry kitchen, the door won't lock, when I hit the temperature button twice the frost light appears ?
this a problem water level switch
Remove the air hose from the water level switch, and blow into the hose,as hard as possible, to clear any debris that may have accumulated in the hose.
Remove the lower panel, and remove the filter from the drain pump and check and clear any debris from the filter and the interior of the pump, and hoses.
Oct 02, 2012 | Bosch Washing Machines
Bosch logixx 7 door wont open
After trying to find manual and doing it the right way with no success my son solved the door problem with a metal fork. Where your hand meets the handle (inside the door drum) shove the fork in to force the clip open. Not the outer edge of the door, theres no locking system there - behind the actual handle.
Apr 03, 2012 | Bosch Logixx WAS2446 Front Load Washer
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
Bosch flashing F23 fault and door wont open tried to reset by manually draining and resetting power but no joy
this has just happened to my Bosch, means the base pan is leaking water...I've had 4 problems with mine in the past and WILL NOT BUY BOSCH AGAIN, poor customer service too.
Nov 19, 2009 | Bosch Logixx WFT 2806 Front Load...
I need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Aug 31, 2009 | Bosch Washing Machines
Bosch logixx 10 washing mashine
just turn filter cap. outer door is just a hinged flap
Aug 05, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
