Question about Kenwood KM800 Major Classic Stand Mixer
Where can i get a circuit board for a andrew james mixer model no qf-3473a
I need a mixer blade for Andrew James hand mixer
Fixya does not sell replacement mixer blades.
Jul 29, 2017 | Food Mixers
My andrew james mixer has just stopped working any ideas was working one day next day nothing
The motor may have failed or the plug you are using has no power.
Oct 20, 2016 | Food Mixers
It's a 1994 ksm5 model and the circuit board is broken . It worked before I moved and was in storage for 4 months????
If you already know the board is broken the sensible solution is to replace the board at the same time keeping your eyes open for whatever may or may not have broken it to start with.
Jan 02, 2016 | KitchenAid KSM150PS Artisan Series Stand...
My Kitchenaid Mixer Model KSM150Ps is tripping my breaker after replacing the speed control board.
Try a different Receptacle outlet if it trips that breaker you know its the mixer, and there will prob be a short/loose connection somewhere
Nov 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
No power REPAIR MANUAL FOR ANDREW JAMES MODEL QF-3473
how to remove the shaft,1/2 sheered into the hub.how can i remove it@
Dec 10, 2012 | Kenwood KM800 Major Classic Stand Mixer
STAND MIXER SPINS FOR A SECOND OR SO THEN STOPS
can you clarify a little more, it is either a gear problem or an electric problem, are there any other symptoms? Like sound noises, grinding fast speed when it does run for those few seconds or really slow. if it is running fine while it does run then it is more likely a speed plat or phase control board. please let us know
Sep 13, 2012 | Food Mixers
Cuisinart SM55 circuit board replacement or wiring chart.
I have a Cuisinart 5.5 quart stand mixer. but its count down model does't work. it move as fold model when I push on button. I guess the circuit board was broken. Is my guess right? Where can I buy the Cuisinart SM55 circuit board and how to replace it?
Jul 23, 2012 | Food Mixers
Kenwood PCB
Hi, maybe your circuit its not burning, in theses models its normally the capacitor or triac, resistor as well,
with just change thats components the machine working again
regards
Kenwood Chef Restore
Nov 10, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood KM800 Major Classic Stand Mixer Logo
95 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
