Question about Fuji film FinePix Z70 JX520 JV200 Z900EXR T200 Original BC-45A Battery Charger fits Fujifilm NP-45 Without Power Cord
My camera won't charge
Camera won't charge
  • sheila gray Nov 02, 2012
    My camera won't charge up.
    New Friend:
Your battery probably is in the wrong way.So take it out and look on the bottom of it.You will see 3 copper cubes.Next look in to the slot where the battery goes and you will see 3 metal wires.Now take your battery and carefully line up the copper slots with the metal wires.Then push the battery in and close the battery slot.And your done go plug it into your USB slot and you will see a white battery symbol and you will know that it is charging.
Simple fix for a simple problem.
Posted on Jun 21, 2013
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
My Coleman Xtreme won't charge. Help!
Hello, my camera is doing the same thing, did you ever find out what the problem is and how to bypass this
Mar 01, 2013 | Coleman C5wp-bk Xtreme C5wp 12mp 33ft....
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
Won't charge
You have a Dead Kodak !!! needs to go to shop.
Sep 24, 2012 | Kodak EasyShare M532 Digital Camera
Camera still dead with a new charged battery. Is it possible to overcharge a battery so it won't work?
If you have another battery definitely give it a try, most likely it won't work either. The problem is probably the fuse located on the DC/DC board that has 'blown' causing there to be no power. Replace the board and the camera should work fine. Canon will probably charge $175 or so for the repair.
Hope this helps.
Thomas
Sep 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
My camera won't charge, and won't turn on. Should I assume I need a new battery, or is there a problem with my camera?? It's only about 2 years old. Not sure what to spend money on...
If you can't neither charge the battery through USB nor the wall charger, I would advise to first replace the battery. If that does not help, it will be difficult to tell if it's worth repairing or replacing the camera.
Aug 10, 2011 | Olympus SP800UZ Digital Camera
My kodak easyshare MD41 has had charging issues since I bought it.. The USB cable that came with the camera won't fit right into the camera's port. I really had to push to get it in. Well, now it...
You will just need to buy a new cable.
Something like this:
http://www.amazon.com/Kodak-EasyShare-MD41-USB-Cable/dp/B003HMVF70
Hope this helps! Good luck!
Jul 27, 2011 | Kodak EasyShare MD41 Digital Camera
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
Fuji film FinePix Z70 JX520 JV200 Z900EXR T200 Original BC-45A Battery Charger fits Fujifilm NP-45 Without Power Cord Logo
141 people viewed this question
Top Fuji Photography Experts
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
