Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
Flang-Back Adjustment Hi I replaced the CCD on my DCR-TRV22E Do I need to follow the flang-back adjustment procedure? Can you access this menu by yourself or is it specified for Sony service personal only? Kind regards, Bert My reply is bit technical. Your camera requires Flang-Back Adjustment. Above said adjustment will set focus lenses in correct order / position to obtain crispy focus as it was before. There are few special tools designed by Sony used in Flang-Back adjustment and only Sony Service Centers can perform such adjustments. Non-Sony repair shops do not have such things. Just for reference, below view shows required tools for adjustments in this model. Need further info let me know please.
  • 38 Answers
Why don't you try www.247servicecenterinfo.com, they have listing of all service service centers in india.
Posted on Jul 01, 2009
Everything has a blue and yellow ring around it
Hello lomain,
I posted this for another person, but it fits your situation so here are my suggestions:
This is not a bad tube it is a convergence problem. Your convergence amplifiers are malfunctioning, and need to be replaced. If you have a background in electronics, you can remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Shuttle83
Mar 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Toshiba 42" suddenly has blue arc projecting through lower half of screen. Confirmed it was the blue tube by removing the projector lens and looking at the direct image.  Is this a bad tube or something...
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Mar 23, 2009 | Toshiba 42H83 42" Rear Projection...
Lost software for sony dcr trv22e
pls follow the link and download ur softwares/drivers pls rate me FIXYA for this if u like i am here to help u further
http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=odw_en_GB&m=DCR-TRV22E
Mar 12, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Red convergence outline
I posted this before, however it fits your situation so here are my suggestions:
I hope this helps,
Thank you,
Shuttle83
Mar 10, 2009 | JVC AV-56WP74 56" Rear Projection...
Focus issues
Nov 27, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
No Picture in Record Mode
Camera has bad/ defective CCD Imager and it needs to be replaced. Good news is that Sony will repair it free of cost. Follow this web link of Sony for details.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV22&news_id=161
Jun 10, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Losing focus
Usually this is a back focus problem; also called a flange back adjustment.  If the back focus adjustment is possible on this camera, zoom out wide - open iris all the way - and adjust focus and lock position.
Nov 06, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
SONY TRV22E - BLANK LCD and cant see through viewfinder
Hi, I called Sony support center in Sweden (my home country). They told me that it's probably a failure in CCD-ship. In such a case, Sony takes the fully responsibility and will repair it without any fee. You only need to pay for one way mail transport. Tobias Rundgren Karlshamn
Aug 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Black lcd
Previous 1 2 3 4 5 Next Notice to Owners of Sony Camcorder October 3, 2005
Thank you for your support and patronage of Sony Camcorders.
It has recently come to our attention that a limited number of Sony Camcorders that incorporate an image sensor device, CCD Chip, manufactured from October 2002 through March 2004 may exhibit the following condition:
When the Camcorder is used in camera mode, the LCD panel and/or electronic viewfinder will show either a distorted image or no image.
We have determined that this condition only occurs to a limited number of units.
In its effort to ensure customer satisfaction, Sony has elected to offer a free repair to the owners of applicable Camcorders if the image sensor device, CCD chip, causes one of the above-mentioned conditions. Accordingly, customers who have a Sony Camcorder as outlined below and if such Sony Camcorder exhibits the above-mentioned condition caused by the image sensor device, CCD chip, may contact the special call center number below for free repair:
CCD-TRV108E
CCD-TRV208E
CCD-TRV218E
CCD-TRV228E
CCD-TRV418E
CCD-TRV428E
DCR-DVD100E
DCR-DVD101E
DCR-DVD200E
DCR-DVD91E
DCR-HC14E
DCR-HC15E
DCR-HC16E
DCR-HC18E
DCR-HC20E
DCR-HC30E
DCR-IP45E
DCR-IP55E
DCR-IP5E
DCR-IP7E
DCR-PC101E
DCR-PC103E
DCR-PC104E
DCR-PC105E
DCR-PC106E
DCR-PC107E
DCR-PC115E
DCR-PC120E
DCR-TRV12E
DCR-TRV145E
DCR-TRV147E
DCR-TRV14E
DCR-TRV16E
DCR-TRV18E
DCR-TRV19E
DCR-TRV22E
DCR-TRV238E
DCR-TRV239E
DCR-TRV240E
DCR-TRV245E
DCR-TRV24E
DCR-TRV250E
DCR-TRV255E
DCR-TRV25E
DCR-TRV265E
DCR-TRV27E
DCR-TRV33E
DCR-TRV340E
DCR-TRV40E
DCR-TRV460E
DCR-TRV50E
DCR-TRV738E
DCR-TRV740E
DCR-TRV940E
DCR-TRV950E
DCR-VX2000E
DCR-VX2100E
Please Call
UK - 08705 143480
Eire - 021 434 8993
Note: If the fault is not the CCD chip, then normal Sony Central Services charges apply (please call for details).
We apologise for any inconvenience caused and we thank you for your understanding of this situation.
Sincerely,
Sony
Private information control policy
Personal information, such as your name and/or mailing address, provided to the contact above will be kept and used only for the free repair service. The information will be strictly controlled and will not be used for any other purposes.
May 16, 2007 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
