Question about HP : HP4P Laserjet Printer
Hp laserjet 4mp
My printer is printing white columns down any pages I print ou. I have put two new cartridges in. HELP!!! What could be causing this? Thanks marytj
    Genius:
  • 2,985 Answers
Contact HP.s Tech support site re this
Posted on May 18, 2007
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
Replace cartridge on hplaserjet2300dn
Hello!
Thank you for your inquiry.
HP LaserJet 2300dn The HP LaserJet 2300dn printer is the same as the HP LaserJet 2300n printer, except that the printer comes with a built-in duplexer (for automatically printing on both sides of paper).
Here is a link to the user guide that will help help you with a lot of common problems including managing the print cartridge area on beginning on page 68. http://www.avss.ucsb.edu/download/hp2300man.pdf
If this is a new toner cartridge the installation instructions will be included inside the packaging including instructions on eco-sensitive means of disposal of old cartridge.
If this is your first time installation you will find it's very simple.
  • Turn the printer off.
  • Open the top cover.
  • If new - remove any orange tabs labeled remove 1st. If this is a replacement cartridge grab the old toner cartridge by the finger hold indentation and pull up.
CAUTION
To prevent damage to the print cartridge, do not expose it to light for
more than a few minutes.
Be careful not to touch the transfer roller (the black, rubber roller located
underneath the print cartridge). Skin oils on the roller can cause
print-quality problems.
  • Install the new print cartridge. It should slide easily down the guide slots on either side.
  • Close the top cover.
Note:
If the print cartridge is difficult to reinstall, make sure that the registration
plate has been flipped back down into position and that you have
pushed the print cartridge firmly in place.
  • Power the printer back on.
Hope this helps helps. Please keep us updated and remember to rate this answer.
Thanks for using FixYa,
TF
May 16, 2011 | HP LaserJet 2300dn Printer
Our HP Laserjet P4015N is printing funny. When printing out a column of information, it will continue to print the information above it, in the white space below the column of numbers in a grey tone. I...
Hell
The "ghost print" you are getting is caused the fuser, even with 60% life left. We have seen this type of wear pattern happen if you print more on one side of the page than the other, or print darker images than standard use would be. The fuser heat roller is coated with Teflon to prevent the toner from sticking to it but when the coating gets worn down you get the ghosting like you have. You can replace just the fuser or you can get the whole maintenance kit and just keep the pickup rollers for later use. If you open the back of your printer so you can see the fuser you should be able to see the heat roller and most likely you will notice a worn area that is not the same color as the rest of the roller.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | HP LaserJet P4015N Printer
Laserjet 4MP paper jam problem Half feeds from
I have seen this issue before and your problem is likely due to very fine paper dust on the pickup rollers. This is easy to fix and takes only a few minutes. Use a soft piece of cloth (not a paper towel), a computer cleaning towelette or anything that does not produce lint; dampen it (unless your are using a towelette) slightly with cleaning alcohol and wipe off the paper pickup roller on all sides. You should also remove the toner cartridge and vacuum out the interior of your 4MP, use care if you are not used to poking around the interior of HP printers. You will usually find both white paper dust and maybe some black toner dust. Put the cartridge and paper tray back in place, print a couple of blank sheets as a test - you should be good to go.
Oct 03, 2009 | Office Equipment & Supplies
Printing black line down middle of page when coping
The fuser is located in the back of the printer. I think it's held in by to screws. It's about hte same size as the toner cartridge. Please visit these websites.
This is the fuser kit.
http://store.printerprinciple.com/products/rm1-3044
The service repair manual.
http://www.scribd.com/doc/15253671/HP-Laserjet-3055-Repair-Manual
Fuser Replacement is on page 170.
Aug 08, 2009 | HP LaserJet 3050 All-In-One Printer
Printing Blank page
1: try another toner cartridge (or possibly pull the seal from the side of the cartridge you have just installed)
2: If it's not the cartridge causing the problem take it back - it has 1 year warranty.
Mar 18, 2009 | HP LaserJet 1020 Printer
I have just tried to install new (HP) printer cartrige
Clean the static strip on the printer, details should be in the manual on how to do this. Also verify that your imaging unit and fuser are in good condition.
Mar 05, 2009 | HP LaserJet 1005w Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 1200 not printing in one area
your fuser is truly unhappy..time for a new fuser
May 28, 2008 | HP LaserJet 1200 Printer
Open Questions:
ricoh aficio sp C232SF / c231sf When enabled, initializes but does not print Ricoh Aficio SP C232SF / c231sf The situation is. When enabled is initialized, writes that greeedy and is in readiness. No mechanism at this time does not work, except the scanner line. Scanning Starts, black and white is faster than the ruler, the color is slow. The document feeder works off a sheet and hands. After all the manipulations on the display Processig shines indefinitely no mechanism works until you press stop. The same situation when you try to print reports or when sending to print from a computer. the driver stood on the USB bus. Using command center see it all, but printing is also not achieved. Sees the tray and the presence of paper. Now this is the strange print though, and no, the black toner decreases. Already there was an inscription about it on the display and in commands the center shows the decrease in black. Only black. If you press for example copying, will stand and-writes about the heating of the stove no mechanical work and after a couple of seconds is ready. Stove at this time safely lying on the table next to the machine. the line Lamp is normal, but no power is supplied to it. The power supply did not find any problems. In the service you start the registration-work out the engines of development and tape, and a couple of auxiliary. Tried to make init EEPROMy, tried to rewrite the data in it, as if installing a new one-no changes Any ideas and assumptions are accepted And for dessert - a main Board, engine and the controller changed. The situation is quite similar. Sew and successfully both through the grid and through the USB port. I don't know where to look
Sep 23, 2018 | Ricoh Office Equipment & Supplies
See all HP : HP4P Laserjet Printer Questions
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
